 Post subject: Multimeter questions
 Post Posted: Sat Jan 16, 2010 8:56 pm
COMPAQ- is the brand of computor-perhaps same as HP I don't know. Scott mentioned in his 18th. edition about useing a multimeter in testing voltages in a computor, is it a high Z model? I still have a V.T.V.M. that has a 100,000 ohm per volt impedance with a wheatstone bridge built in. most multimeters I have owned are rather low Z about 20,000 ohm per volt, which can load down a delicate system. _ carl
 Post subject: Re: Vista and intenet explorer script errors
 Post Posted: Sun Jan 17, 2010 8:56 am
You can use any type of voltmeter on a computer. Old style analog ohm meters however (e.g. those with internal 9V batteries) should not be used on digital circuits. For measuring resistance, use a modern digital VOM instead. Scott.
 Post subject: Re: Multimeter questions
 Post Posted: Sun Jan 17, 2010 6:38 pm
Dear Scott, I have a Digital meter that talks to me so I don't have to take my eyes off what I have the Probe on. It is also has a 7 Segment Liquad Crystal Display, I have never had it apart, so what powers the LCD if it does not have batterries or battery in it ?- Carl
 Post Posted: Sun Jan 17, 2010 8:05 pm
Your meter sounds fine, you just don't want one that uses 9V batteries. Scott.
 Post Posted: Mon Jan 18, 2010 12:31 pm
Dear Scott I see where you are coming from, Most resistors etc. are double rated in voltage etc. Back when I was being schooled in Tech School, I am not disagreeing , just stateing what I was taught, I agree that 3- 5 volt powered meter is safer, The V.T.V.M. only used a 1 1/2 volt battery= Thanks For your prompt and polite answers !- Carl
 Post Posted: Wed Sep 27, 2017 2:01 am
scott Why don't you want to use a meter with a 9v batteries?
 Post Posted: Wed Sep 27, 2017 2:06 am
What are digital circuits?
is a voltmemter same as a mutiltmeter?
 Post Posted: Wed Sep 27, 2017 10:28 pm
Digital circuits are binary circuits in a computer that typically work on switching 5V (or lower voltage) signals. Compare this to analog circuits, which use continuously variable signals of any voltage level.
...is a voltmemter same as a mutiltmeter?
A voltmeter measures voltage. A multimeter measures voltage, current and resistance. Multimeters include a voltmeter.
Because only older (mostly analog) multimeters use 9V batteries and injecting 9V into a circuit that runs on only 3V or less may cause damage. Scott.
 Post Posted: Fri Oct 13, 2017 3:29 am
Now would this be also with a digital multimeters that use a 9v batteries as well.
have you seen a 9v batteries that is higher then 9v like 10v what is the deal with that. I test a new 9V battery and it shows as 10v on three meters....
weird...
 Post Posted: Fri Oct 13, 2017 8:44 am
Any digital multimeter would be fine no matter what battery it used.
The zero-load voltage of an alkaline battery can be up to 1.65V. Since a 9V battery has 6 cells it can show a no-load voltage of up to 9.9V
 Post Posted: Fri Oct 13, 2017 3:44 pm
Scott. I have Radioshack Digital Auto Ranging Multimeter. It's Catalog no. 22-801. This is the only thing I could find on it. I still have the manual and everything. I don't remember when I purchased it but it does have a 9 Volt battery. I assume it's fine. I just opened it up today to check it out. I changed the battery and it seems to power up fine. Only remember using it once to try "back-probing" a PSU as described in your book.
I'm guessing you really miss RadioShack Scott.
 Post Posted: Fri Oct 13, 2017 8:30 pm
That meter should be fine. I have been a customer of Radio Shack since the early 1970s and even worked at a store for a short time in the early '80s. They are an American institution. While they are not gone they are not what they used to be (but neither is anything else): https://www.radioshack.com/
