Author |
Andrew-B
Post subject: There is a problem with my tri - color print cartridge. Posted: Sat Dec 01, 2012 11:05 pm |
I have a HP Photosmart 7450 Series printer.
I'm using windows XP.
I have purchased a tri - color ph 6657a (57) cartridge two days ago, When I installed the new ink cartridge I keep getting the error message below:
print cartridge has failed.
the color print cartridge (#57) has failed. please replace it or remove it to print using ink backup printingmodes.
my HP Photosmart 7450 Series printer is two years old. I would be grateful for advice for some help.
Andrew-B
Post subject: Print cartridge cradle Stuck issue. Posted: Sat Dec 01, 2012 11:06 pm |
have a hp photosmart 7450 series printer.
I'm using windows Xp.
What is the Print cartridge cradle and the cradle path?
where is the Print cartridge cradle and the cradle path located?
Thank you for any advice you are able to give me!
Post subject: Re: There is a problem with my tri - color print cartridge. Posted: Sat Dec 01, 2012 11:32 pm |
Site Admin |
There's not much I can say except to replace the cartridge or the printer. I despise printers in general and ink-jet printers are the worst, I won't use them myself. I'd recommend getting a color laser instead. Scott.
glen4cindy
Post subject: Re: There is a problem with my tri - color print cartridge. Posted: Sun Dec 30, 2012 7:22 pm |
Joined: Thu May 31, 2007 8:37 pm Posts: 201 Location: St. Louis, MO
I would have to 2nd Scott's recommendation on this matter.
Right now, you can get a very good home use Color Laser printer for about $125 that will serve the needs of the average home user very well.
My Color Laser uses 4 toners, they rarely all go out at the same time, (once I think). I usually get well over 1 year of use out of a set of cartridges. Generally, you are going to get 2000 pages out of a color cartridge. (Try that with an Inkjet).
Try not printing anything for a month and see how well your Inkjet likes you. Your Color Laser doesn't give a rip. They dry powder doesn't care. It works as well sitting for a month unused as it does being used every day.
Given the number of pages you will get and the length of time the cartridge lasts, the supplies cost is very low for most home use Color Laser units as opposed to the cheap Ink Jets.
Maxirad
Post subject: Re: There is a problem with my tri - color print cartridge. Posted: Mon Jan 07, 2013 10:46 pm |
David McMahon
Post subject: Re: There is a problem with my tri - color print cartridge. Posted: Mon Jan 07, 2013 11:30 pm |
Joined: Thu Jan 15, 2009 1:27 pm Posts: 1105 Location: Stowmarket, Suffolk England
glen4cindy
Post subject: Re: There is a problem with my tri - color print cartridge. Posted: Tue Jan 08, 2013 12:33 pm |
Maxirad
Post subject: Re: There is a problem with my tri - color print cartridge. Posted: Sat Feb 18, 2017 10:52 pm |
