Scott Mueller's Upgrading and Repairing PCs Forum • View topic - BOOT: like faded phone ring (Id-ent-i-cal) then a P.O.S.T.
 Post subject: BOOT: like faded phone ring (Id-ent-i-cal) then a P.O.S.T.
 Post Posted: Sun Apr 07, 2013 12:24 pm
Hello,
DELL OPTIPLEX 780 (SFF)
JUST out of warranty.
SERVICE TAG: 9Z9K5M1
EXPRESS SERVICE CODE: 21723414121
WINDOWS XP PRO – upToDate (S.P. 3)
AVAST! Vs. 7.01
Yesterday tried typing on email and message kept erasing itself (I would click mouse and it would erase text). I have installed new mouse HOWEVER, MORE WORRISOME:
On boot, (cold and warm) there is ringing from the “tower” (like a muffled phone) IRregular - like an id-ent-i-cal and then a POST (1)
RAN: virus check (full, quick, and boot scan: All negative.)
RAN: MalWareBytes – negative.
No new updates | no new H/W / S/W (EXCEPT: uploaded music from DVR but problem did not occur until several days later)
PC has always had issues I think due to the SFF (size) causing xs heat.
SO: Is it heading for death?
Which component?
Please advise!
P.S. I think the mouse erasing text issue was due to the mouse (I replaced it and so far so good (relatively) but the PC still rings).
P.P.S.:
I got 3 dells 3 years ago: (with the optiplex total was 3). I was not very happy with them. Is this a fluke? Or has Dell deteriorated? What other manufacturers would you suggest (that I can order my own components for) - I.E. that allow one to choose certain things?
Thank you!
 Post subject: ?SOLVED? Re: BOOT: like faded phone ring then a P.O.S.T.
 Post Posted: Sun Apr 07, 2013 5:32 pm
I think the problem was solved: I replaced the mouse and the ringing and P.O.S.T. stopped!
Thanks
I still would be interested in any advice on PC brands?
 Post subject: Re: BOOT: like faded phone ring (Id-ent-i-cal) then a P.O.S.
 Post Posted: Tue Apr 09, 2013 5:12 pm
I'm glad the new mouse solved the problem, thanks for letting us know. While I would generally recommend building a system over buying one pre-made, for new pre-made desktop systems I would recommend Dell or HP, but I'd want to be careful to choose a system using industry standard ATX or microATX form factors. For laptop systems I only recommend ThinkPads. Scott.
 Post Posted: Tue Apr 09, 2013 6:27 pm
Hi,
Thank you for replying.
I did *start* to build my own system (2005) (2 - one intel based the other AMD-based) but
1. It was really time-consuming
2. It was going to cost a lot more than a pre-made system.
3. I was told that the main advantage of building one was for gaming which I do not do.
4. I found there were some obstacles because I was in Canada
Maybe things have changed?
For my next laptop I will definitely follow your advice because out of absolute stupidity and naivety I got an Acer which is unusable.
Thanks
 Post Posted: Tue Apr 09, 2013 7:26 pm
The cost for building vs. buying has changed over time. At times it has been cheaper to build, other times it is cheaper to buy. Right now I think building is favored especially if the system will be re-built in the future. That's because a home built system will use industry standard parts, so that any and all parts can easily be upgraded or replaced in the future. Even if you currently have a pre-built system, if it uses industry standard chassis, PSU and motherboard form factors you can save a large amount of money by re-using the existing case and other components when building a "new" system. Another way to save is to re-use the existing OS. This can even be done with normally non-transferable OEM versions using the .
As for time, it only takes a few minutes to assemble a new system from scratch. I recommend watching the build-a-PC segments on the video included with my (just released, I got my first copies the other day!) for more information on fast and easy system building. Scott.
 Post Posted: Thu Apr 11, 2013 2:30 pm
 Post Posted: Thu Apr 11, 2013 3:16 pm
 Post Posted: Thu Apr 11, 2013 6:41 pm
 Post Posted: Thu Apr 11, 2013 8:00 pm
Yes indeed, you sure can! Scott.
Users browsing this forum: Majestic-12 [Bot] and 3 guests
