 Post subject: Adding more RAM to an old PC that has had its memory maxed.
 Post Posted: Thu Oct 03, 2013 6:49 pm
Hey all.
I have an emachine T2085. I was wondering if I used a riser to expand the slots would that enable me to add more memory? Also, are there risers for that specific purpose?
Thanks. :D
 Post subject: Re: Adding more RAM to an old PC that has had its memory max
 Post Posted: Thu Oct 03, 2013 7:13 pm
I don't think so! I'd get a new motherboard with higher memory capacity, does that board have two or four slots?
 Post Posted: Thu Oct 03, 2013 7:35 pm
Two. If I replace the motherboard, and have considered that, would that effect my accessing the programs on the HDD? It's always been the crux of my issue. It's the whole "programs w/o original program disc" thing. Had the system a long time.
 Post Posted: Thu Oct 03, 2013 7:49 pm
No, however you can install two 1GB modules for a total of 2GB, which would be more than enough for that system when running Windows XP or earlier versions.
If you replace the motherboard you'll need to also replace the processor, RAM and PSU. In that case you could just build a new system re-using the existing chassis. Scott.
 Post Posted: Thu Oct 03, 2013 7:51 pm
Thanks! The devil didn't I consider that. :lol:
 Post Posted: Wed Oct 23, 2013 2:31 pm
At times, you can add more RAM than the manufacturer claims to support. For instance, I was able to run a little over 3GB in my Inspiron e1505 with the original core duo processor and the 32 bit Vista, though Dell only claimed it would support 2GB. Swapping in a Core2Duo and the 64 bit version of the OS, it was able to see all 4GB that I'd installed.
There was also a BIOS update involved...
 Post Posted: Wed Oct 23, 2013 4:34 pm
The online store sold me DDR1 ram for my laptop. I tried to explain that the specs said DDR of a specific type. Guy tried to tell me they were the same generation and should work. My research said otherwise. Wound up returning for a refund. Waiting on that, mean time I found the exact type of RAM needed.
Is DDR1 even produced still?
 Post Posted: Wed Oct 23, 2013 4:44 pm
http://www.crucial.com/store/listmodule/DDR/list.html
 Post Posted: Wed Oct 23, 2013 4:52 pm
Thanks. I'll add that to the list of part sites I'm growing. :-)
 Post Posted: Wed Oct 23, 2013 5:29 pm
The system scanner they have is very useful, also guarantees compatibility.
