 Post subject: How do I see the whole error message
 Post Posted: Thu Oct 24, 2013 1:46 am
I've been trying to figure out the source of this R6002 error message for a while now and can't seem to find the problem. How do I expand the attached error message to see the troublesome program?
 Post subject: Re: How do I see the whole error message
 Post Posted: Thu Oct 24, 2013 9:45 am
An error like that is normally due to a bug in the software generating it. What was the last program you installed before the error began appearing? Can you make the error appear at will, if so how?
There is no way to expand that Window, however you can check the Event Viewer to see if the error has been logged, which should indicate the program generating the error. Scott.
 Post Posted: Thu Oct 24, 2013 1:01 pm
It appears when I try using Media Player Classic and some other programs like a video cutter-joiner. If I re-install K-lite or the video programs, they'll work fine for about 5 minutes, then the error reappears. Quite annoying.
 Post Posted: Thu Oct 24, 2013 2:07 pm
Try uninstalling and reinstalling Microsoft Visual C++ 2010 SP1. Programs written in C++ call on that and if the installation is corrupted problems such as you are having can result. Scott.
 Post Posted: Fri Nov 01, 2013 8:56 pm
Seems a free program called Icon Tweaker causes the floating point error problem. I've always liked replacing the WinXP icons with Win 7 icons. Gives XP a more modern look. Is there another way to update all the icons in XP without using a program?
 Post Posted: Sat Nov 02, 2013 9:48 am
I'm glad you found the offender. I don't have any specific recommendations, but there are many Windows icon and other appearance customizing tools available here. Let me know if you find something you like, Scott.
