 Post subject: Lenovo H430 BIOS Update Mess Up
 Post Posted: Wed Jan 01, 2014 10:27 am
I'm trying to repair a Lenovo H430 that won't boot. A BIOS update was run via flash update and when the system was restarted it won't POST. Any ideas?
Evan
 Post subject: Re: Lenovo H430 BIOS Update Mess Up
 Post Posted: Wed Jan 01, 2014 11:10 am
If it won't POST (and it did before the BIOS update), that means the update went bad. If that's the case then you can investigate BIOS recovery procedures for that motherboard, if any exist. I don't see any mentioned on the support page but there might be a way. A motherboard replacement would be the only other solution.
If it will POST but won't boot, that means something went bad with the OS, boot device, etc. Note that BIOS update says "This BIOS only support windows 32 bit" so make sure you are booting from a 32-bit version of Windows. Scott.
 Post Posted: Wed Jan 01, 2014 11:16 am
I haven't seen any BIOS recovery procedures yet, that's why I came here.
Evan
 Post Posted: Wed Jan 01, 2014 11:32 am
Would this MSI motherboard work as a replacement?
Evan
 Post Posted: Sun Jan 05, 2014 7:26 pm
Evan
I can't believe they only have a Windows flash and no boot CD, USB or even floppy BIOS.
Yes, that looks like it will do.
http://download.lenovo.com/consumer/des ... h4_hmm.pdf
http://download.lenovo.com/consumer/des ... online.pdf
Be aware the LAN and likely the audio drivers are different. There is no HDMI port on that board. Make sure the case has a removable rear I/O port panel.
 Post Posted: Sun Jan 05, 2014 10:20 pm
The original and suggested replacement motherboards are both microATX. As long as the processor socket and supported memory types are the same then it should work as a replacement. Scott.
