Scott Mueller's Upgrading and Repairing PCs Forum • View topic - Case fans worth recommending?
 Post subject: Case fans worth recommending?
 Post Posted: Wed Feb 01, 2017 11:05 pm
Scott, are there any case fans that you would recommend? It seems to me that I need a fan that's 120mm x 120mm x 25mm. I'm thinking about getting a myself.
 Post subject: Re: Case fans worth recommending?
 Post Posted: Wed Feb 01, 2017 11:21 pm
Look up the active heatsink fan recommendations in my book. Does that one meet the most important criteria? Let me know what you find... Scott.
 Post Posted: Thu Feb 02, 2017 12:09 pm
Uh-oh! That one site describes the bearing type for the Blade Master 120 as "Long Life Sleeve." Scott, there's no doubt in my mind that you would prefer case fans with ball bearings. Would you really prefer that a case fan plug directly into a motherboard, or is it OK if such a fan utilizes a power-supply connector?
 Post Posted: Thu Feb 02, 2017 9:31 pm
 Post Posted: Mon May 01, 2017 6:30 pm
I installed in the case of my usual desktop PC today. The case fan has a 4-pin plug, but the system's motherboard only has a 3-pin socket for it. The fan does spin when connected.
 Post Posted: Mon May 01, 2017 8:02 pm
4-pin fans are backwards compatible with 3-pin sockets. When plugged into a 3-pin socket a 4-pin fan will work as a 3-pin fan. Scott.
