Author |
spiderman
Post subject: about what magnetic nut setter Posted: Thu Dec 28, 2017 2:16 pm |
I was wondering and I been looking around the local hardware stores around here and I can't find a magnetic driver 3/16. all I can find is a set of nut setter electric screwdriver. what is the difference between a nut driver and a nut setter. Do you use a magnetic nut driver or a nut setter When I google it I find mix information about it.
the set I got sometime 5mm nut setter don't fit around the nut like say around the VGA port on the desktop and the laptop etc then I have to use a nut driver screwdriver not electric then i can remove it.
thanks for the help...
Post subject: Re: about what magnetic nut setter Posted: Thu Dec 28, 2017 11:44 pm |
Site Admin |
spiderman
Post subject: Re: about what magnetic nut setter Posted: Fri Dec 29, 2017 1:33 am |
Post subject: Re: about what magnetic nut setter Posted: Fri Dec 29, 2017 8:43 pm |
Site Admin |
I think they would be fine. I've been magnetizing my tools for years, it helps for holding non-stainless steel hardware. Scott.
spiderman
Post subject: Re: about what magnetic nut setter Posted: Sat Dec 30, 2017 8:57 am |
Post subject: Re: about what magnetic nut setter Posted: Sat Dec 30, 2017 11:44 am |
Site Admin |
Search and ye shall find. I'll add that I use very strong removed from discarded hard drives to magnetize my tools. I have several of these magnets on all of my toolboxes just for that purpose. Scott.
spiderman
Post subject: Re: about what magnetic nut setter Posted: Sat Dec 30, 2017 5:24 pm |
