Scott wrote:
That is the PoWer Manager IDle TaSK program, which is automatically
installed as part of the ThinkPad Power Manager software.
It is enabled or disabled depending on the options you select in your power
scheme battery and AC settings. In particular, one of the power scheme
options is to lower the display brightness after a period of inactivity in
order to save power. If you enable this feature, the PMTask listed in
Scheduled Tasks will be enabled, as it is used to control this feature. You
should not delete this task. Scott.
Thanks a lot Scott!.
