 Post subject: NVIDIA Quadro NVS 140M and TurboCache
 Post Posted: Fri Aug 19, 2011 6:00 pm
The NVIDIA Quadro NVS 140M in my T61 only has 128MB of built-in memory, but according to http://www.nvidia.com/object/quadro_nvs ... specs.html, it supports TurboCache. Many apps of the past few years (or games, if you like) require a minimum of 256MB of video memory. Can the GPU use 128MB from system RAM to give it 256MB effective, allowing those apps to run as long as there is sufficient system RAM for the apps remaining? Thanks.
 Post subject: Re: NVIDIA Quadro NVS 140M and TurboCache
 Post Posted: Fri Aug 19, 2011 6:18 pm
If it truly supports TurboCache, then the answer should be yes. What happens when you try it? Scott.
 Post Posted: Fri Aug 19, 2011 6:22 pm
Nothing yet, I haven't yet tried running anything requiring over 128MB of video RAM. I need a newer, bigger hard drive to install anything of that character.
 Post Posted: Mon Dec 05, 2011 5:28 pm
It works, but frame rate seems to be negatively impacted, creating some difficulty in shooters, mostly with aiming. Likely less of an issue in turn-based games etc.
 Post Posted: Mon Dec 05, 2011 9:59 pm
Don't forget the large speed difference between RAM and VRAM
 Post Posted: Wed Dec 14, 2011 4:45 pm
The difference is somewhat larger than normal, as the PM965 chipset supported a 800MHz FSB, or 6400 MB/ps, but only DDR2 667, or 5333.33 MB/ps. The Quadro NVS 140M, with 600MHz memory and a 64-bit bus, has 9.6 GB/ps bandwidth.
Edit: Overlooked the PCI-E part; it's 16-lane v1.1, so it has 4GB each direction. Memory bandwidth from main RAM to the GPU would be under 4GB/ps. The bottleneck is PCI-E, not the main RAM.
