 Post subject: How long do inverter cards last?
 Post Posted: Sun Aug 28, 2011 8:19 pm
How long does an inverter card on a TP usually last? I'm trying to plan ahead to reduce future downtime, and would like one on hand as is necessary. Thanks.
Also, to test if it's the inverter or CCFL, I assume you could use a DMM to test the voltage output from the inverter. What voltage (or voltage range) should the inverter be outputting if operating correctly?
 Post subject: Re: How long do inverter cards last?
 Post Posted: Sun Aug 28, 2011 8:45 pm
Online
LCD inverters normally last the life of the display. Of course YMMV.
...What voltage (or voltage range) should the inverter be outputting if operating correctly?
Since I believe the output is dependent on a load, the only way I know of to accurately test an inverter would be to plug it in a known-good spare backlight. Scott.
