 Post subject: Wireless-N card for ThinkPad T40p
 Post Posted: Mon Sep 26, 2011 5:36 pm
Do you know if there is a wireless a/b/g/n card for a ThinkPad T40p. Hopefully it will work with Ubuntu. It probably will if it is an older card since they will have had time to put together a driver for it.
If there isn't an n card would using a g card be faster?
The present card is:
Intel Corporation PRO/Wireless LAN 2100 3B Mini PCI Adapter (rev 04)
 Post subject: Re: Wireless-N card for ThinkPad T40p
 Post Posted: Mon Sep 26, 2011 7:29 pm
The existing card supports 802.11b only. Unfortunately I don't believe there are any internal bgn or abgn cards that will work in that system. You could use a Cardbus bgn adapter, but in my opinion the results (i.e. having n over g) would not be worth the expense or having a bulky card sticking out the side. Instead I would recommend upgrading to an internal abg card, which would be a worthwhile, cost effective, and virtually transparent upgrade over the card you have now. Note that you will need to use a card approved for the T40, else you will receive an 1802 error on boot, and the system will be disabled. I believe the Atheros based cards should be supported by Ubuntu, but you would want to confirm that before committing. Scott.
 Post Posted: Mon Sep 26, 2011 7:37 pm
Is the 1802 "feature" common for all Thinkpads?
 Post Posted: Mon Sep 26, 2011 7:52 pm
Unfortunately yes. Just to be sure I recently replaced the Lenovo approved Intel 6300 in my T520 with a non-Lenovo approved version of the exact same card, and immediately received the 1802 error. Reinstalling the approved card rectified the situation. Scott.
 Post Posted: Mon Sep 26, 2011 8:09 pm
Thanks Scott, glad I found out, was planning on getting a 3x3 upgrade for my T400
