 Post subject: How do you find a wifi adapter driver?
 Post Posted: Fri Nov 25, 2011 1:33 am
Got a newer USB wifi adapter or dongle and wanted to find the driver for it. The device info in Device Manager is USB\VID_148/PID_2070\6&1260A5BF&0&2. How do I find the make and model from that? Thanks.
 Post subject: Re: How do you find a wifi adapter driver?
 Post Posted: Fri Nov 25, 2011 8:01 am
You'll find a detailed answer to that question in my article here: Becoming an expert device and driver Detective
Let me know what device/chipset that turns out to be, and where you find the drivers. Scott.
 Post Posted: Fri Nov 25, 2011 1:38 pm
I've used this article before to find the driver using the VEN and DEV numbers. This dongle uses a VID and PID number though. Using Google doesn't seem to work with that.
BTW, how do I find my past posts in this forum, just using my login name. When I try "username" or "*username", I get nothing. I have to try and remember the subject title. Thanks.
 Post Posted: Fri Nov 25, 2011 7:53 pm
It does if you use the correct numbers to begin with. <g> Since VIDs are 4 digits I suspect that the actual VID in question is 148F (and not just 148 as you posted). Combined with a PID of 2070, according to the usb.ids database posted by the USB ID Repository that points to a Ralink Technology RT2070 device, for which you can find the drivers on the Ralink site here.
...how do I find my past posts in this forum, just using my login name.
Click on your Profile, then select Search user's posts. Scott.
