Scott Mueller's Upgrading and Repairing PCs Forum • View topic - Overheating During Video after Reflowing Mobo
 Post subject: Overheating During Video after Reflowing Mobo
 Post Posted: Sat Jul 28, 2012 12:53 pm
The following thread is for this system:
ThinkPad T40p (2373-G5U)
Operating System:Windows 7 32bit
P M 1.6GHz, 2GB RAM, 40GB 7200rpm HDD, 14.1 SXGA+(1400x1050) TFT LCD, 64MB ATI Fire GL 9000, SuperMulti Drive DVD(slim), Modem/Bluetooth, 1Gb Ether, 802.11a/b/g , Sec Chip, UltraNav, 9 cell Batt
For support from Lenovo on this particular system:
1. go to .
2. click the "Use Quick Path" link, and type in: "2373G5U".
When I type in "lspci" in a terminal in Ubuntu linux I get:
"VGA compatible controller: ATI Technologies Inc Radeon RV250 [Mobility FireGL 9000]"
I don't know if that helps, but I thought I would include it.
In December the system wasn't working after I dropped it. I successfully reflowed the motherboard by cooking it in a normal kitchen oven. The reflow was documented .
Recently the system has been running hot, especially when viewing videos. If I try running a video for a long period of time, sometimes I get these little horizontal lines all over the display. The fan is almost always running. It didn't run so much before. If I stop playing a video, the system temperature comes down right away. It will get as high as 77 degrees Celsius and idling it runs around 38 degrees.
I'm thinking the only way to fix the system is probably to get a reconditioned motherboard. There are several models that will run in the T40p. Are there any you would recommend over the others?
 Post subject: Re: Overheating During Video after Reflowing Mobo
 Post Posted: Sat Jul 28, 2012 2:50 pm
I don't see how a reconditioned motherboard would help, a chip doesn't generate more heat as it ages. However, a cooling system certainly can become less efficient over time due to fan wear, dust/dirt, and degradation of the thermal interface material. I would therefore recommend checking the fan to be sure it is clean and operating normally (at full speed), and if not I would clean and/or replace it. I would also renew the thermal interface material, especially that between the GPU and heatsink. Scott.
 Post Posted: Sat Jul 28, 2012 7:52 pm
Thanks. I'm glad I didn't get the new motherboard.
I'm trying to do a good job on reseating the fan assembly. On page 105 of the "Hardware Maintenance Manual" a "Thermal Rubber" is mentioned. It attaches the fan heat sink to the GPU and cools it.
The one that is on there now has a lot of dust on it. Maybe that is why it is not cooling the GPU.
I can't find an FRU for this thermal rubber. Do you know where I can get one?
 Post Posted: Sat Jul 28, 2012 8:42 pm
I think people use Copper shims to replace the rubber's as rubber is far less conductive than copper!
 Post Posted: Sun Jul 29, 2012 9:50 am
Thanks, I'll try that. As soon as I do it I'll post the results here.
 Post Posted: Sun Jul 29, 2012 10:56 am
 Post Posted: Wed Feb 13, 2013 12:20 am
Implied by the Hardware Maintenance Manual for my T61 (it's unclear if it's speaking of installing a new Fan assembly, a used Fan assembly, or both), thermal grease should be re-applied to the rubber pads when re-installing the Fan assembly. I'm curious as to whether the pads assist in cushioning the CPU die from the weight of the Fan assembly and pressure from typing on the keyboard.
