 Post subject: acer aspire laptop - need to write zeros to drive to return
 Post Posted: Tue Sep 18, 2012 8:50 pm
Hi
Sorry this is not the format
LAPTOP: ACER ASPIRE NX.RZGAA.002
SNID: 22105840034
I have to return this defective laptop by tomorrow and need to write zeros to the drive urgently.
The problems: mainly pointing devices do not work; VERY slow; etc....
I tried kill disk but the "kill" function cannot be highlighted.
I read about KNOPPIX but don't know anything about it.
ACER is no help.
Is there a utility that you recommend that does this?
Thank you
 Post subject: Re: acer aspire laptop - need to write zeros to drive to ret
 Post Posted: Tue Sep 18, 2012 9:49 pm
I have to return this defective laptop by tomorrow and need to write zeros to the drive urgently... Is there a utility that you recommend that does this?
Yes indeed, I use and recommend DBAN. Download the image and burn the bootable disc. Then boot from the disc and use the *Quick Erase* function, which overwrites the entire drive in a single pass. Not only does it do a complete job that way, it only takes a few minutes to an hour or so, and the data will be completely unrecoverable thereafter. Scott.
 Post Posted: Tue Sep 18, 2012 11:12 pm
Thank you so much!
 Post Posted: Wed Sep 19, 2012 7:55 am
Scott: help
I downloaded dban then winzip: There are 100 or so files - I don't know which to use?
Thanks
 Post Posted: Wed Sep 19, 2012 11:55 am
You don't need WinZip. DBAN is an ISO file, which is an image of a CD-ROM. You would use something like ImgBurn to burn that image to an actual disc (CD-R recommended, but you could use a DVD+-R if that's all you have). Then boot from the disc and use the *Quick Erase* function to overwrite the entire hard drive in a single pass. Scott.
 Post Posted: Wed Sep 19, 2012 12:34 pm
I tried every possible method but it would not boot off the CD (regardless of boot order, etc.) (I also had tried without winZip)
I formatted it
They picked it up and replaced it....
I need to post a new subject re laptops
:oops:
Thanks!
 Post Posted: Wed Sep 19, 2012 1:28 pm
If it wouldn't boot from the disc then I would suspect the optical drive was defective, which is unfortunately very common. If you formatted the drive using Vista or later then that would have wiped it as well, at least all of the data area.
 Post Posted: Wed Sep 19, 2012 3:18 pm
Windows 7
I have the replacement laptop now which functions far better.
As you mention I m sure the optical drive was defective There were many other issues too.
Thanks!
