 Post subject: Beep codes
 Post Posted: Thu Dec 20, 2012 4:53 pm
I have a Dell Inspiron 6400 (Service Tag F1D6TC1) that fires off 15 beeps in rapid succession (no gaps) after the boot sequence but before Windows starts. Then Windows starts normally and behaves itself (so far).
The original OS was Vista Basic and it has been upgraded to Win7 Home Premium SP1.
When I run Belarc it tells me that 2 updates are missing:
1) Q2728973 (Unrated)
2) Q2753842 (Critical)
But according to Windows Update, all updates have been installed.
I'm not sure that has anything to do with the beeping. The keyboard seems to be functioning well too.
Any ideas?
 Post subject: Re: Beep codes
 Post Posted: Thu Dec 20, 2012 5:44 pm
Beeping during the POST (Power On Self Test) normally indicates a hardware problem. That system should have hardware diagnostics on a hidden partition that can be run during startup. To run it, press and hold the <Fn> key while powering the system on. Follow the prompts to run the system diagnostics. First try the Express Test, then if that passes try the Extended Test. Let me know what you find. Scott.
 Post Posted: Thu Dec 20, 2012 11:31 pm
Thanks Scott,
After an hour+ of testing I got an error code of 2C00:0421, a second code of 2C00:021C and a third of 2C00:031B.
The keyboard test showed that the Page Down key would not respond correctly. Looks like a new keyboard is needed.
 Post Posted: Fri Dec 21, 2012 12:18 am
Replace the keyboard and re-run the tests. Let me know what you find, Scott.
 Post Posted: Fri Dec 21, 2012 4:28 pm
The customer doesn't want to replace the keyboard. I guess it's been bad since day one and he never thought to have it checked out before. The "Page Down" key isn't one he uses very often, if ever and all the other keys work. He uses the laptop during the months he's in Florida during the winter and even then he isn't on his computer very often. Fixing it would probably be a bad investment for him. Hey, if he's happy.........
 Post Posted: Sun Dec 23, 2012 10:41 pm
Maybe worth cleaning the ribbon cable, or just using a USB keyboard if/when the other keys start to fail
