Scott Mueller's Upgrading and Repairing PCs Forum • View topic - Unable to install windows
 Post subject: Unable to install windows
 Post Posted: Fri Sep 06, 2013 11:10 pm
Hi scott, Laptop-compaq presario cq58,250GB(toshiba),4GB,AMD processor,window7. Problem:"windows cannot be installed on this drive" I get this message when about to start a fresh installation.the previous windows crashed.pls help out.thanks in advance.
 Post subject: Re: Unable to install windows
 Post Posted: Sat Sep 07, 2013 4:27 am
I'm working on a new CQ58 (Win8) myself.
Did you try the factory recovery disc/option?
I would check the drive for errors, (this one has a Hitachi drive)
If you check the drive disable AHCI in the bios (if you can)
You might also just be trying to install to a recovery, or small diagnostic partition. If you want to use that drive, first delete all the partitions, after you have backed up of course.
 Post Posted: Sat Sep 07, 2013 8:15 am
If you are using standard installation media you will probably need to supply the *during* the installation. Have them ready on a USB flash drive and point the installation to them when prompted. As an option you may be able to disable AHCI mode in the BIOS Setup, however that may impact performance slightly. Scott.
 Post Posted: Sun Sep 15, 2013 8:05 am
Thanks scott & David.I tried everything but no headway still so i decided to try another Hdd.It worked.when I tried to use the suspected Hdd externally via a 2.5"PATA/SATA COMBO,data could hardly be transfered to it.(the combo worked fine with a known good Hdd).I guess the Hdd is faulty.
 Post Posted: Sun Sep 15, 2013 10:45 am
HDD's are like spinning plates, you need more than one to continue eating if one falls?!?
