 Post subject: What to use to clean screens?
 Post Posted: Thu Dec 18, 2014 11:20 pm
Scott, what product do you recommend to clean screens? Thanks.
 Post subject: Re: What to use to clean screens?
 Post Posted: Fri Dec 19, 2014 3:14 pm
Lately I've been using standard automotive windshield washer fluid (diluted 1:1 with distilled water) for cleaning screens, chassis, keyboards or just about any external surfaces on a computer. It is very inexpensive at just around a dollar or two for a gallon, which I then dilute with a similarly inexpensive gallon of distilled water. For many years I used only hot water on the screens, but I have never had problems with my washer fluid mix. In either case I would only apply the solution to dampen (but not soak) a soft cloth which I would then use to wipe the system down, immediately followed by a soft dry cloth. Scott.
