Scott Mueller's Upgrading and Repairing PCs Forum • View topic - Thoughts on refurbished Thinkpad
 Post subject: Thoughts on refurbished Thinkpad
 Post Posted: Mon Jun 29, 2015 4:21 pm
Do you think this is a good deal?
I'm looking to buy another thinkpad, but don't have a lot of money to spend. I looked at the Lenovo outlet, but didn't see anything similarly priced.
Thanks for any thoughts.
Paul
 Post subject: Re: Thoughts on refurbished Thinkpad
 Post Posted: Mon Jun 29, 2015 11:20 pm
Actually I think that is an excellent deal, especially with it being a Certified Refurbished unit and with free shipping. In addition the T420 was one of the last models made before Lenovo screwed up the TrackPoint and keyboard. I would have no problems recommending that unit. Scott.
 Post Posted: Fri Jul 17, 2015 2:54 pm
 Post Posted: Fri Jul 17, 2015 4:29 pm
 Post Posted: Sat Jul 18, 2015 6:16 am
Spiderman - yes I did get one and I'm happy with it. It arrived quickly, came well-packaged, and appears in great condition. I like the fact that it came with absolutely no crapware. In any case, I upgraded to an SSD drive by cloning the hard drive with this device:
http://tinyurl.com/nhrqyx3
and so far it runs like a charm.
I almost purchased the 4GB RAM version for $269 instead. Again, I'm satisfied with the purchase.
 Post Posted: Mon Jul 20, 2015 11:05 am
 Post Posted: Mon Jul 20, 2015 1:29 pm
I got an e-mail back from the seller saying this screen resolution on this laptop is 1366 x 768 is that good or bad. some people say they got screen resolution 1600 x 900.
 Post Posted: Mon Jul 20, 2015 4:41 pm
That is a personal preference issue. Higher resolution is generally better since you get more desktop real-estate (especially desirable if you often run multiple apps/windows), but the higher number of pixels per inch results in smaller icons and text on-screen. Some of this can be tweaked via Windows and application settings, but that isn't always possible and can be a bit of extra work to implement. For that reason I normally like to run with default settings where possible.
As an example my current laptop has a 15.6" screen with 1600x900 resolution and I like it, however due to my eyesight changing with age I sometimes have to use reading glasses to see it clearly. I would not accept that resolution on the smaller 14.0" screen on a T4xx for example (I would need bifocals or reading glasses all the time), and some people might not want it even with a 15.6" display. Scott.
 Post Posted: Tue Jul 21, 2015 1:54 am
have you had yourself check for diabetes?
the dell laptop might have a bad motherboard is display is 1280x800.
and the thinkpad t420 1366x768 is that better then 1280x800?
 Post Posted: Tue Jul 21, 2015 2:22 am
 Post Posted: Fri Jul 24, 2015 7:16 pm
On that T420 do you know what the max amount of ram that can be install. on this model is there a stick of ram solder on the motherboard. What is the max size hard drive can be install on this T420.
 Post Posted: Fri Jul 24, 2015 10:19 pm
I believe there are 2 SO-DIMM sockets (no memory is soldered-in) and the maximum supported is 8GB (two 4GB modules): https://support.lenovo.com/us/en/documents/pd015734
 Post Posted: Thu Aug 20, 2015 6:36 pm
