 Post subject: Thoughts on refurbished Thinkpad
 Post Posted: Mon Jun 29, 2015 4:21 pm
Do you think this is a good deal?
http://www.amazon.com/gp/product/B00W4AMWCI?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
I'm looking to buy another thinkpad, but don't have a lot of money to spend. I looked at the Lenovo outlet, but didn't see anything similarly priced.
Thanks for any thoughts.
Paul
 Post subject: Re: Thoughts on refurbished Thinkpad
 Post Posted: Mon Jun 29, 2015 11:20 pm
Actually I think that is an excellent deal, especially with it being a Certified Refurbished unit and with free shipping. In addition the T420 was one of the last models made before Lenovo screwed up the TrackPoint and keyboard. I would have no problems recommending that unit. Scott.
 Post Posted: Fri Jul 17, 2015 2:54 pm
Lenovo Thinkpad T420 - Intel Core i5 2520M 8GB 320GB Win 7 Pro (Certified Refurbished)
scott
I was wondering what core is this a 2 core or quad core.
I look on Intel website and it said it a 2 core. but it said its a 64bit windows 7 pro and cpu is a 64bit.
I just order one of these and this is for the person that post this
did you get yours and what you do you think of it.
thanks you
Spidermand
Scott please read my other post about this dell laptop about the power and won't boot up when it is plug in. i have an update to it.
 Post Posted: Fri Jul 17, 2015 4:29 pm
scott
You can see the processor specs here: http://ark.intel.com/products/52229/Int ... o-3_20-GHz
According to the specs that is a dual-core processor with Hyper-Threading Technology, which makes it appear as 4 cores to the OS. Scott.
 Post Posted: Sat Jul 18, 2015 6:16 am
Spiderman - yes I did get one and I'm happy with it. It arrived quickly, came well-packaged, and appears in great condition. I like the fact that it came with absolutely no crapware. In any case, I upgraded to an SSD drive by cloning the hard drive with this device:
http://tinyurl.com/nhrqyx3
and so far it runs like a charm.
I almost purchased the 4GB RAM version for $269 instead. Again, I'm satisfied with the purchase.
 Post Posted: Mon Jul 20, 2015 11:05 am
Did it came with a USB 3.0
What screen size resolution did yours came with yours was it 1600 x 900.
and did yours came with a cd-rw /dvd-rw drive combo.
and does this also have a esata port.
 Post Posted: Mon Jul 20, 2015 1:29 pm
I got an e-mail back from the seller saying this screen resolution on this laptop is 1366 x 768 is that good or bad. some people say they got screen resolution 1600 x 900.
 Post Posted: Mon Jul 20, 2015 4:41 pm
That is a personal preference issue. Higher resolution is generally better since you get more desktop real-estate (especially desirable if you often run multiple apps/windows), but the higher number of pixels per inch results in smaller icons and text on-screen. Some of this can be tweaked via Windows and application settings, but that isn't always possible and can be a bit of extra work to implement. For that reason I normally like to run with default settings where possible.
As an example my current laptop has a 15.6" screen with 1600x900 resolution and I like it, however due to my eyesight changing with age I sometimes have to use reading glasses to see it clearly. I would not accept that resolution on the smaller 14.0" screen on a T4xx for example (I would need bifocals or reading glasses all the time), and some people might not want it even with a 15.6" display. Scott.
 Post Posted: Tue Jul 21, 2015 1:54 am
have you had yourself check for diabetes?
the dell laptop might have a bad motherboard is display is 1280x800.
and the thinkpad t420 1366x768 is that better then 1280x800?
 Post Posted: Tue Jul 21, 2015 2:22 am
Yes, I am fine in that regard. It is normal for eyesight to move more farsighted as one ages, which makes it more difficult to clearly see high resolution computer screens close-up.
...the dell laptop might have a bad motherboard is display is 1280x800.
Both of those are equivalent resolutions, only the aspect ratios are slightly different. 1280x800 (WXGA) is 16:10 while 1366x768 (WXGA-HD) is 16:9.
Note that 1366x768 on a 14.0" display is 112 pixels per inch (PPI), which is basically the same as the 116 PPI from 1600x900 on a 15.6" display. In my experience any PPI higher than that requires young eyes with excellent vision. Scott.
 Post Posted: Fri Jul 24, 2015 7:16 pm
On that T420 do you know what the max amount of ram that can be install. on this model is there a stick of ram solder on the motherboard. What is the max size hard drive can be install on this T420.
 Post Posted: Fri Jul 24, 2015 10:19 pm
I believe there are 2 SO-DIMM sockets (no memory is soldered-in) and the maximum supported is 8GB (two 4GB modules): https://support.lenovo.com/us/en/documents/pd015734
 Post Posted: Thu Aug 20, 2015 6:36 pm
pcliff wrote:
Paul
I just wanto to point something out here about the hard drive in this T420
4 inches
Processor Intel Core i5
RAM 8 GB SO-DIMM DDR3
Hard Drive 320 GB HDD 5400 rpm
Wireless Type 802.11bgn
Expand
Other Technical Details
Brand Name Lenovo
Series Thinkpad T420
Hardware Platform PC
Operating System Windows 7;
Item Weight 4.5 pounds
Item Dimensions L x W x H 13.50 x 1.20 x 8.80 inches
Color Black
Computer Memory Type DDR3 SDRAM
There hard drive says it is a 320gb hard drive the speed of that drive is not 5400RPM it is 7200 RPM even better. Just that to let you know I did the crystal disk info and it shows the RPM 7200. Just a thought in cause anyone want to get one of these awesome T40 laptop computers or get yourself one of those crappy dell laptops lol <g>
