Scott Mueller's Upgrading and Repairing PCs Forum • View topic - the sysRq key don't work
 Post subject: the sysRq key don't work
 Post Posted: Fri Aug 07, 2015 11:11 am
On my laptop T420 thinkpad
I would like to know what does this key do the FN + SysRq
It seems not to be working?
I can get the PrtSc key to work just find for copy and paste the screen to the clipboard and into wordpad.
thanks
Spiderman!
I also would like to know if I should install these software updates on this laptop too
here is a screen shot. I think I have them all ready up to date.
 Post subject: Re: the sysRq key don't work
 Post Posted: Fri Aug 07, 2015 12:25 pm
 Post Posted: Fri Aug 07, 2015 1:29 pm
the only one that it did not download and install was the windows 7 update module KB2661796 64BIT. I try to install it manually but it said this see photo and what does that mean. ?
 Post Posted: Fri Aug 07, 2015 1:33 pm
What about these optional updates.
 Post Posted: Fri Aug 07, 2015 10:27 pm
I'd probably install the display and WLAN drivers but not the password manager. Scott.
 Post Posted: Sat Aug 08, 2015 4:20 pm
 Post Posted: Sat Aug 08, 2015 7:57 pm
 Post Posted: Sat Aug 08, 2015 8:52 pm
after install the intel WLAN driver - 7 [64bit}
I notice the wifi
what is the different between the wireless and wifi
see the photo does it look right to you.
What is the different between the Microsoft virtual Wifi miniport adapter and the Microsoft virtual WiFi miniport Adapter #2 and what do they both do.
thanks.
 Post Posted: Sat Aug 08, 2015 9:29 pm
 Post Posted: Sat Aug 08, 2015 10:33 pm
Solution
Instructions on how to uninstall Microsoft Virtual WiFi Miniport adapters from the Device Manager:
Download the Intel Wireless LAN software file for your system from Lenovo eSupport download site and extract the file onto your system.
Run the Intel WLAN software installer using autorun.exe or setup.exe.
Select “modify install”.
Uncheck “Intel My WiFi Technology”, then click Next.
Follow the instructions on the screen to complete the modify installation.
After installation is completed, one Microsoft Virtual WiFi Miniport Adapter remains in the Device Manager as expected.
Open a command prompt as an administrator.
Type the command “netsh wlan set host mode=disallow” and press Enter.
The other Microsoft Virtual WiFi Miniport adapter disappears from the Device Manager.
Restart Windows.
In the photo
which one do I pick. If here any more information I can give you let me know I can snipping tool the version of drivers for the networking card.
I just want to make sure I download the right one and able to uninstall those wifi miniport
network card take a look at those ok
 Post Posted: Sat Aug 08, 2015 11:01 pm
You pick the latest driver for your specific WiFi adapter and OS. Most likely that is the 2nd one in the list, check the readme file to be sure. Scott.
 Post Posted: Sat Aug 08, 2015 11:19 pm
 Post Posted: Sat Aug 08, 2015 11:37 pm
Let me know if that is the correct one. Scott.
 Post Posted: Mon Aug 10, 2015 5:22 pm
 Post Posted: Mon Aug 10, 2015 8:42 pm
