Scott Mueller's Upgrading and Repairing PCs Forum • View topic - Defective motherboard?
 Post subject: Defective motherboard?
 Post Posted: Sun Dec 13, 2015 10:14 am
 Post subject: Re: Defective motherboard?
 Post Posted: Sun Dec 13, 2015 10:21 am
replace the MB battery ... nice link BTW
 Post Posted: Sun Dec 13, 2015 1:38 pm
 Post Posted: Mon Dec 14, 2015 12:28 am
It could also be a defective main battery. The battery in a laptop that old would normally be dead (or nearly so) and the CMOS battery would most likely be dead as well. What happens when you replace the CMOS battery and run the system without the main battery installed? Scott.
 Post Posted: Wed Jan 20, 2016 1:01 pm
Scott, I've located the CMOS battery in the laptop that I have.
File comment: Location of CMOS battery in Averatec 4200 Series laptop.
Is there a particularly good way to get it out? How do I put in a replacement?
 Post Posted: Wed Jan 20, 2016 1:45 pm
You just unplug it and plug in a . You can purchase a for a few bucks or replace the battery in the existing unit using . Scott.
 Post Posted: Wed Jan 20, 2016 2:10 pm
Scott, I have stuff to replace the current battery with. My big concern is that the current battery is not in a socket. It appears to be held in place by an adhesive.
 Post Posted: Wed Jan 20, 2016 3:58 pm
The cable connecting the battery to the motherboard is plugged into a socket. You will of course need to unplug it before you can plug in the replacement.
Note that different 2-pin connectors may be used by different models so you will want to insure that your replacement battery has the same connector as the existing one. If not you can splice the existing cable and connector to the cable on the replacement or attach a new bare battery to your existing cable using the method shown in the last link in my previous post. Scott.
 Post Posted: Wed Jan 20, 2016 4:32 pm
I have tried but failed to remove the cable from its socket. Would using tweezers be a good idea?
 Post Posted: Wed Jan 20, 2016 5:47 pm
The connector is a self-latching friction fit type, similar to that used for cooling fans. Normally you just grab the wires and pull. A tweezers used improperly could cause damage to the cable, connector or possibly even the motherboard. Scott.
