 Post subject: how do you test A cpu fan in a laptop
 Post Posted: Sun Aug 13, 2017 7:16 am
How would I test a cpu fan in a laptop computer to see if it is working at all.
Is there any cpu fan tester device out there to do that.
 Post subject: Re: how do you test A cpu fan in a laptop
 Post Posted: Sun Aug 13, 2017 8:27 am
I have found one way that I found to test cpu with a usb cable.
I striped the wires and then put the red to red and black to black wires and then plug it in and the cpu fan ran.
but there got to be a some kind of a device out there to test cpu fans if they are bad or not.
there is another way I found to is using a 9volt battery and plug in the red and black wires into the cup fan and that would work to.
I guess I just go bored this weekend.....
 Post Posted: Sun Aug 13, 2017 8:57 am
To test fans I connect them to a power source of the proper voltage and see if they spin smoothly without any noise from the bearings. Scott.
 Post Posted: Wed Aug 30, 2017 3:11 am
What power source do you use to test cpu fans.....???
 Post Posted: Wed Aug 30, 2017 9:22 am
I normally use a standard ATX power supply (known-good spare) that I have sitting on my workbench, but in some cases I've also used batteries. Scott.
