Author |
FatGuy
Post subject: New laptop Posted: Fri Feb 09, 2018 7:53 pm |
My . It's painfully slow and has soldered in RAM to the motherboard. Sure you can upgrade the one slot. The soldered one if 4GB though and it had 8GB total. So adding ram in pairs so it works in dual channel mode isn't possible. Correct me if I'm wrong but when adding ram you need to match the capacity and speed for the ram to run in dual channel mode. Correct?. So why limit the user to single channel mode by soldering in the RAM like this?. Maybe it wouldn't be much of a noticeable difference but it just seems dumb to limit the potential of the system like this.
Post subject: Re: New laptop Posted: Fri Feb 09, 2018 8:26 pm |
Site Admin |
FatGuy
Post subject: Re: New laptop Posted: Sun Feb 11, 2018 12:36 am |
I've been googling looking to find out if it has m2 slot or not. I even chatted with support and the guy said he didn't know. Even if I found out it had a m2 slot, I've been reading that some boards or laptop manufacturers have it there but don't allow you to boot from it for some reason. They don't provide any info about the motherboard having an m2 slot or not anywhere on the support page. What do you think Scott?. Would I just be better off getting a 2.5 inch Sata SSD?.
FatGuy
Post subject: Re: New laptop Posted: Sun Feb 11, 2018 1:21 am |
FatGuy
Post subject: Re: New laptop Posted: Sun Feb 11, 2018 1:28 pm |
I saw someone posted that on an acer forum that I could run a Nvme m2 SSD but it would only run and have available 2 lanes. I don't understand why that would be the case because there are different models that I'm sure use the same motherboard but come with m2 ssd. The motherboard has an m2 slot and it's "M keyed".... https://en.wikipedia.org/wiki/M.2
FatGuy
Post subject: Re: New laptop Posted: Sun Feb 11, 2018 1:36 pm |
Actually I think those markings are for the type of screws it uses. Hahaha!
FatGuy
Post subject: Re: New laptop Posted: Sun Feb 11, 2018 2:26 pm |
FatGuy
Post subject: Re: New laptop Posted: Sun Feb 11, 2018 2:27 pm |
Do SSD's really generate much heat?. I mean they aren't being accessed constantly and HDD generate much more heat...
FatGuy
Post subject: Re: New laptop Posted: Mon Feb 12, 2018 5:41 pm |
I believe the guy I talked to on a forum was just talking out his ass. Today I chatted with Acer support and told him what this kid in the forum said. He told me that it was inaccurate and there is no limitation on the m2 slot of the motherboard for my wifes laptop.
FatGuy
Post subject: Re: New laptop Posted: Mon Feb 12, 2018 8:59 pm |
Just figured out on my own that this laptop isn't actually compatible with a pci express 3 x 4 SSD. Yes it has an M2 slot, but I don't believe it has a pci express 3.0 bus, so it would just be Sata 3.0. So it would make more sense upgrading it with a 2.5 inch Sata SSD instead.
FatGuy
Post subject: Re: New laptop Posted: Mon Feb 12, 2018 11:24 pm |
For some reason I was confusing the m2 port and not realizing that m2 can be pci express 3.0 x4 and also Sata 3. I don't believe this laptop even has a pci express bus. Also if I use the it only lists 2.5 inch sata drives.
FatGuy
Post subject: Re: New laptop Posted: Mon Feb 12, 2018 11:26 pm |
Just have to remember that different ports can support different types of busses for those devices. M2 supports Sata 3 and also pci express 3.0 x 4.
FatGuy
Post subject: Re: New laptop Posted: Mon Feb 12, 2018 11:30 pm |
Yet another reason to only get Thinkpad laptops. With any other brand it seems you have to be a detective to find out what your product supports. For this laptop you even have to take the bottom cover off completely just to remove the damn battery.
FatGuy
Post subject: Re: New laptop Posted: Tue Feb 13, 2018 3:08 pm |
FatGuy
Post subject: Re: New laptop Posted: Thu Feb 15, 2018 7:45 pm |
Scott, in your next upgrading and repairing pcs could you go into more detail on M2 slots and also different interfaces. Plus include detailed information on NVME.
Post subject: Re: New laptop Posted: Thu Feb 15, 2018 8:34 pm |
Site Admin |
I sure will, thanks for the suggestion. Scott.
FatGuy
Post subject: Re: New laptop Posted: Thu Feb 15, 2018 8:57 pm |
I went to look up m2 and SSDs in your current U&R pcs and there wasn't much in there about it. It gets confusing with the different module "keys" or I guess different types of connections/connectors.
FatGuy
Post subject: Re: New laptop Posted: Fri Mar 02, 2018 7:58 pm |
Scott I ordered a to upgrade the crappy HDD in this new laptop. Since the battery is on the inside, should it be disconnected just to upgrade the HDD?. I thought that whenever working on a laptop the battery was suppose to be removed. However I've not worked on or even seen a lot of laptops. The last few laptops I have seen have had easily removable batteries. This one doesn't The battery is inside the laptop.
I can take it apart and just disconnect the battery cable I guess.
FatGuy
Post subject: Re: New laptop Posted: Fri Mar 02, 2018 8:06 pm |
I could easily disconnect the battery while I'm in there. The link also says it's installing a "secondary" hdd. So since this will be a replacement instead of a secondary drive than some steps won't be necessary. Particularly the steps to open up the entire case and "install the hard drive cable", since obviously it'll already be installed!.
However, what I'm asking is should I do the steps to remove the lower or bottom side of the case just to disconnect the battery?.
FatGuy
Post subject: Re: New laptop Posted: Fri Mar 02, 2018 8:22 pm |
Hard drive in there now is . So since it is 7mm, than I should not need an adapter, correct?.
The physical specifications are nearly identical except the width for the Seagate says 69.85mm and the Samsung is 70mm. Unless the specs on newegg aren't exact like the ones I linked on the seagate site.
FatGuy
Post subject: Re: New laptop Posted: Fri Mar 02, 2018 8:47 pm |
So I talked to Samsung support and he explained to me that those adapters are meant for older laptops since they had different height hard drives. So I guess I don't need one.
Post subject: Re: New laptop Posted: Fri Mar 02, 2018 11:23 pm |
Site Admin |
I recommend not buying stuff you don't need. <g> Scott.
FatGuy
Post subject: Re: New laptop Posted: Sat Mar 03, 2018 12:54 pm |
Ok thanks!. What about disconnecting the battery?. Last I remember is it was recommended to always remove the battery from a laptop before working on it.
FatGuy
Post subject: Re: New laptop Posted: Sun Mar 04, 2018 1:01 pm |
I didn't bother with disconnecting the battery. Everything went great. Now the laptop is amazingly faster. The difference is very noticeable. Very worthwhile investment indeed.
Post subject: Re: New laptop Posted: Sun Mar 04, 2018 4:40 pm |
Site Admin |
I'm glad the SSD installation went well and that you noticed the performance improvement. I do recommend removing the main battery before working on a laptop but in the case of a simple SSD installation it won't really matter. Scott.
