I am wondering about the SSD SATA.
I have a dell laptop and it has windows vista and it is a dell inspiron 6400/ E1505 model.
I need to get a new hard drive soon
The hard drive is a SATA not a SSD..
the interface SATA
Transfer mode sata/150mbbs.
Now I was wondering if the SSD faster then the mechanical hard drive I have in it right now even if the SSD can only read at 1.5 Gbps. with the hard drive being that slow would i need a SSD 1 or 2 or 3.
I was also want to know is PNY SSD any good cause at best buy they got one for $49.00 and the size of that hard drive is 120GB SSD it is a bit bigger then the mechanical hard drive and that hard drive is a 80gb
here is the system manaul I wish I can find the specs of the computer but dell took it down for some reason.
http://downloads.dell.com/manuals/all-p ... _en-us.pdfhttp://www.dell.com/support/home/us/en/ ... c1/manuals for the user manual
another thing what do I need to enable slice on the windows vista basic sp2.
and it is a 32bit cpu and windows is 32bit..
and it has 2gb of ram and a duo 1.73 ghz.
thanks if you need more info let me know and I will try to dig hard to find the specs..
