Author |
spiderman
Post subject: I have a question scott about the volt in the RAM Posted: Sat Sep 28, 2019 7:09 pm |
About the Voit in the T530 laptop computer thinkpad that I just got a few weeks ago has mix match the volts one Ram is 1.5V and the other one is 1.35V What does the DDR3L what is the L stand for do you need it or not but here is the screen shots if you need more info or more screen shots let me know thanks. which one would be better ram the 1.5v or the 1.35v Which one soctt that you would pick from here to make 16gb or ram https://www.crucial.com/usa/en/compatib ... nkpad-t530
Attachments: |
FatGuy
Post subject: Re: I have a question scott about the volt in the RAM Posted: Sat Oct 05, 2019 4:58 pm |
Let me try and answer. That laptop that you mentioned I looked up. It has a 3rd generation Intel Cpu in it. DDR3L is a special version that can run at either 1.35 or 1.50. Intel 4th generation processors need the DDR3L because they aren't compatible with regular DDR3. https://www.dell.com/support/article/sg ... ry?lang=en
spiderman
Post subject: Re: I have a question scott about the volt in the RAM Posted: Sun Oct 06, 2019 11:14 am |
FatGuy
Post subject: Re: I have a question scott about the volt in the RAM Posted: Sun Oct 06, 2019 12:01 pm |
Post subject: Re: I have a question scott about the volt in the RAM Posted: Sun Oct 06, 2019 1:39 pm |
Site Admin |
I would give you an A+. As you know just because an article was published by Dell doesn't mean it is valid only for Dell computers. Scott.
spiderman
Post subject: Re: I have a question scott about the volt in the RAM Posted: Sun Oct 06, 2019 10:51 pm |
spiderman
Post subject: Re: I have a question scott about the volt in the RAM Posted: Sun Oct 06, 2019 10:56 pm |
