 Post subject: Low latency laptop memory. Worthwhile?
 Post Posted: Thu Aug 21, 2008 11:34 pm
I was wondering whether you think getting the low latency (CL=4) DDR2-667 laptop memory is worthwhile? I just saw these two SKU's on the Newegg site:
http://www.newegg.com/Product/ProductLi ... 081&name=4
Would I see much, if any, difference when running standard type applications?
The price for 4GB of "regular" (CL=5) Crucial DDR2-667 http://www.newegg.com/Product/Product.a ... 6820148201 is only a little bit less than for the Kingston "HyperX" memory in the link above, worth the extra few dollars?
Thanks as always!
-Paul
 Post subject: Re: Low latency laptop memory. Worthwhile?
 Post Posted: Fri Aug 22, 2008 6:03 am
You'll find the answer in my post here:
Note that in general, the overall system performance improvement from lower-latency memory (i.e. from CL-5 to CL-4) running at the same clock speed would be about the same or less than that resulting from faster memory (i.e. from 533MHz to 667MHz). Scott.
 Post Posted: Fri Aug 22, 2008 11:38 am
Thanks Scott,
so basically not worth paying a huge premium for, but wouldn't necessarily make a huge difference anyway. Can't hurt though, every little bit helps I guess <g>
 Post Posted: Fri Aug 22, 2008 12:06 pm
I've often spent a little extra to get something "better", even though I know that I won't ever be able to notice the difference. <g> Scott.
 Post Posted: Fri Aug 22, 2008 12:11 pm
You mean you can't tell the difference between a $5 and a $100 HDMI cable? <g>
 Post Posted: Fri Aug 22, 2008 12:18 pm
Sure, the $100 one is 20 times longer, right? <g> Scott.
 Post Posted: Fri Aug 22, 2008 12:22 pm
sure, as well as 24K gold plated super-tensile NASA tested connectors and it comes in a nice impenetrable hard plastic case and maybe has a little accessory bag to store it in <g>
