 Post subject: Thinkpad nylon screws
 Post Posted: Thu Oct 23, 2008 5:54 pm
In their service manuals IBM recommends never reusing their screws when servicing Thinkpads:
Screw notices
Loose screws can cause a reliability problem. In the ThinkPad computer, this problem is addressed with special nylon-coated screws that have the following characteristics:
- They maintain tight connections.
- They do not easily come loose, even with shock or vibration.
- They are harder to tighten.
- Each one should be used only once.
Do the following when you service this machine:
- Keep the screw kit (for the P/N, see “Miscellaneous parts” on page 162) in your tool bag.
- Always use new screws.
- Use a torque screwdriver if you have one.
I suspect that most people ignore this advice and have no issues. What is your take on this?
Also they (IBM/Lenovo) are very specific on their recommended screw torque settings. Do you use a special driver when servicing your Thinkpads to meet these specifications?
Thanks!
 Post subject: Re: Thinkpad nylon screws
 Post Posted: Thu Oct 23, 2008 6:24 pm
As an experienced technician who *has* used torque wrenches extensively in the past, and who since then has become capable of judging non-critical (i.e. not life or death) fastener torque by feel, and who also knows by both look and feel when a fastener is worn to the point at which it should be replaced, I will admit that I *do* re-use the screws and do *not* use a torque wrench when working on computers in general, including ThinkPads. Your mileage may vary. <g> Scott.
