 Post subject: Difference between OEM and Retail Product Keys for XP?
 Post Posted: Sat Oct 30, 2010 8:00 pm
Scott, can one if a Product Key for Windows XP is for the OEM verison of XP or for the Retail version of XP just by looking at the key?
 Post subject: Re: Difference between OEM and Retail Product Keys for XP?
 Post Posted: Sat Oct 30, 2010 8:24 pm
OEM sticker should already be on the case, Retail in the packaging sleeve.
I have seen some system builders stick the OEM label on other things, leaflets, motherboard manuals, sometimes not stuck anywhere!
You are supposed to stick them (OEM ones) on the case!
 Post Posted: Sat Oct 30, 2010 8:51 pm
Hmmm....I think this has been discussed before several times.
 Post Posted: Sun Oct 31, 2010 10:23 am
You can tell by looking at the COA, but not just by the key number alone. Scott.
 Post Posted: Sun Oct 31, 2010 11:30 am
Scott, what if you to install XP using a Retail installtion disk with an OEM Product Key? What happens then?
 Post Posted: Sun Oct 31, 2010 12:07 pm
The key will not be accepted. Retail media will only accept retail keys, OEM media will only accept OEM keys, etc. In other words, the type of key has to match the product type of the installation media. Note however, that by editing the Product ID (PID) number in the SETUPP.INI file you can in effect change the media type. Scott.
 Post Posted: Mon Nov 01, 2010 8:47 pm
This might be a silly question, but how can you alter the SETUPP.INI file on an optical disc that's non-rewritable?
 Post Posted: Mon Nov 01, 2010 10:22 pm
You burn a new disc with the edited file. Scott.
