 Post subject: Can not get on to Google
 Post Posted: Mon Apr 04, 2011 11:31 am
Having a problem getting on to the google web site, I can get on to everything else, help!!!!! I have windows 7 Thank You
 Post subject: Re: Can not get on to Google
 Post Posted: Mon Apr 04, 2011 2:37 pm
A website can be blocked via an improper entry in the hosts file. Try resetting the hosts file, which will remove any blocks. If that doesn't help, then your ISP (Internet Service Provider) may be having some problems on their end, which usually will work themselves out after a short period. Try resetting your modem as this may clear that type of issue up. If that doesn't help, then you may have malware on the system, as redirecting or blocking sites is one of the systems. If that is the case you'll either want to remove the malware or reload the system from scratch. Let me know what you find, Scott.
 Post Posted: Wed Apr 06, 2011 4:54 am
Thanks I removed the Malware from the system and that solved the problem
