 Post subject: iTunes has baffled me yet again....
 Post Posted: Fri Apr 15, 2011 7:28 am
i set all my defaults for my music files to open with windows media player and when i turn auto play on my Cd's open with windows media player but for some reason when i dbl click the cd icon in the explorer drive window..the cd opens with itunes i tried surfing the web for a fix but came up short was hoping maybe one of you could help me in the dilemma
 Post subject: Re: iTunes has baffled me yet again....
 Post Posted: Fri Apr 15, 2011 7:33 am
Let me also say that i have tried looking in the itunes settings as well but fell short of finding a solution i am running windows 7 home premium if that helps at all
 Post Posted: Tue Apr 26, 2011 7:39 pm
You might want to try uninstalling iTunes, rebooting, then reinstall iTunes while very carefully reading the installation screens. Many software installations have pre-checked boxes which install toolbars, make the software the default application for it's function, etc. Carefully read each screen during installation and uncheck any box you do not want checked. Nero is notorious for this too.
One more thing, if offered a choice between "Typical Installation" and "Custom Installation", choose the Custom. "Typical" usually installs everything while Custom allows you to "trim the fat" so to speak.
 Post Posted: Wed Apr 27, 2011 3:06 am
I agree but in Windows 7 there is a "Default Programs" option I would try that, is in the start menu so just open the start menu and start typing Default I only had to type in the first three characters!
