 Post subject: Win7; Error message trying to remove user from admin group
 Post Posted: Fri Jul 29, 2011 12:18 am
When attempting to remove an account from the Administrators group, I receive the error message "The specified account name is not a member of the group." I don't recall having left that account as a member of Administrators. Ideas? Thanks.
 Post subject: Re: Win7; Error message trying to remove user from admin gro
 Post Posted: Fri Jul 29, 2011 6:39 am
That's what the error is saying. The account is a member of another group.
It that is not the case, then what happens when you turn off User Account Control? Scott.
 Post Posted: Wed Aug 10, 2011 8:14 pm
Disabled UAC, and the account can control everything without any prompts or requests to run as a new user.
 Post Posted: Tue Aug 23, 2011 1:03 pm
When I view the Administrators Group, it displays as empty, despite other uses being members of it.
 Post Posted: Mon Jan 02, 2012 3:33 pm
I believe this behavior was likely caused by someone (else) using Offline NT Password and Registry Editor to tamper with the SAM, elevating a normal user to admin. This behavior is listed in its FAQ at http://pogostick.net/~pnh/ntpasswd/. Will SysKey, http://support.microsoft.com/kb/310105, protect the SAM from such attacks, and are there any other alternative methods of securing the SAM? Thanks.
 Post Posted: Mon Jan 02, 2012 4:41 pm
I haven't tested SysKey but I don't think it will prevent the removal of the password. I recommend you test it and report on what you find. According to Laws 1-3 of the 10 Immutable Laws of Security, if a bad guy can run their program on your computer, alter the OS, and have unrestricted physical access, then "it's not your computer anymore". <g> Scott.
