 Post subject: Add / remove programs in general and HP Photosmart C4680 MF
 Post Posted: Fri Jan 13, 2012 1:34 pm
Hello,
COMPUTER SPECS:
Dell Dimension E520
Service Tag: 10Z8ZC1
Express Service Code: 2235987937
SYSTEM DETAILS
SYSTEM = Dell Dimension E520
CPU = Intel ® Core ™2 CPU; 2.13 GHz; Bus speed: 1066 MHZ; L2 cache 2 MB; dual; 64 bit
MOTHERBOARD = Motherboard: Dell Inc. 0WG864?
RAM = 2.0 GB; DIMM 1 (1 GB) and 2 (1 GB) nonECC; unbuffered; x8; 667 MHz; DDR2 SDRAM Dual interleaved
HARD DRIVE = Seagate – SATA RAID; 500 GB;
OS = Windows XP (Home) SP3 (up to date)
POWER SUPPLY = 305 W
VIDEO CARD = NVIDIA GeForce 7300 LE PCI Slot 10 (PCI bus 1, device 0, function 0)
SOUND CARD = Integrated audio:
BIOS 2.2.1 (03/23/07)
Relevant Software
Avast! Free version, 6.0.1289 completely up to date.
Email Client: Thunderbird: version 2.0.0.24 (20100228)
Internet Explorer: 7.0.5730.13 BrowserJavaVersion: 1.6.0_18 (Don’t use)
Firefox: Version: 3.6.13
“Dell™ Dimension™ E520 Owner's Manual”
http://support.dell.com/support/edocs/s ... 730A01.pdf
Installed a HP Photosmart C4680 - September 2011) but IMO the PC has slowed since then; There was also an HP Installation Error – XP)
Currently, it is not printing at all: Hit “print” and nothing – no error message etc. It copies though.
(This occurred right after dealing with a “Paper Jam” (which was not evident))
I tested the printer on another PC and it works fine.
So I should reinstall the HP software?
PRINTER (Multifunction)
“HP Photosmart C4600 All-in-One Printer series overview - HP Products and Services Products”
http://h10010.www1.hp.com/wwpc/ca/en/sm ... 39148.html
1. Which better in general?
Add/Remove Programs
Or
The software’s own uninstall option?
2. To ensure all of the HP S/W is gone, is uninstalling again in safe mode a good idea?
Also for other programs – Is safe mode more thorough?
3. Reinstalling the HP software: Since it had an “accident” during original install, should I install it under safe mode?
(Also for other programs)
Many Thanks!
 Post subject: Re: Add / remove programs in general and HP Photosmart C4680
 Post Posted: Fri Jan 13, 2012 9:31 pm
Yes.
1. Which better in general? Add/Remove Programs Or The software’s own uninstall option?
Those are two different ways of executing the exact same functions. In other words, it doesn't make a difference which method you choose since they will do the exact same things.
2. To ensure all of the HP S/W is gone, is uninstalling again in safe mode a good idea? Also for other programs – Is safe mode more thorough?
I recommend uninstalling the software normally. If you have a problem uninstalling, then I recommend using the Program Install and Uninstall Troubleshooter.
3. Reinstalling the HP software: Since it had an “accident” during original install, should I install it under safe mode? (Also for other programs)
It is best to install programs with the system booted normally and logged in to a user account with adminstrative privileges. Scott.
 Post Posted: Sun Jan 15, 2012 9:34 pm
Thank you for replying.
Reason I ask: I heard when installing a program it's best to have Windows restart the PC vs. the program....
So I thought using add/remove is better because it is the OS vs. the program uninstalling....
:oops:
Thanks
Users browsing this forum: Bing [Bot] and 6 guests
