 Post subject: to play .3gp format in WMP
 Post Posted: Fri Oct 26, 2012 4:04 pm
What decoder is best to play .3gp format in windows media player?
 Post subject: Re: to play .3gp format in WMP
 Post Posted: Fri Oct 26, 2012 4:36 pm
You should be able to play .3gp files using the built-in codecs included with MPC-HC or the VLC media player (my favorite), or possibly in Windows Media Player with one of the K-Lite Codec Packs (which includes codecs supporting 3gp) installed. Note that MPC-HC is also included with the K-Lite Standard and higher packs. Scott.
 Post Posted: Fri Oct 26, 2012 4:53 pm
which did you click on to download the install package or the 7zip package or the zip packackage?
 Post Posted: Fri Oct 26, 2012 6:08 pm
The installer is an executable (.exe) file, there are no zip packages. For example, if you want the Mega Pack the executable installer file can be downloaded from 8 different sources starting with Mirror 1 (Betanews). Scott.
 Post Posted: Fri Oct 26, 2012 6:39 pm
I meant the VLM media player....
 Post Posted: Fri Oct 26, 2012 7:30 pm
In this case I would use the executable installer. Scott.
