 Post subject: Right Click: Properties
 Post Posted: Sat Dec 22, 2012 1:54 am
Any idea why when I right-click on say...anything...there is no window like usual? Yes, I plan to do a re-install, but does anyone know what system call isn't working here?
Evan
 Post subject: Re: Right Click: Properties
 Post Posted: Sat Dec 22, 2012 2:58 am
What happens when you try a different pointing device? Scott.
 Post Posted: Sat Dec 22, 2012 3:37 am
Tried a wireless mouse vs the touchpad. Same results, but my first statement should be revised. On this machine, I'm running Vista. If I click on the start orb and the righ-click on the "computer" entry I get the expected window (general info and info regarding my system rating). Where I noticed the problem was when I brought up the Network and Sharing Center window via the taskbar. After selecting "Manage Network Connections" on the left side of the window (under "Tasks") this brings up "Control Panel->Network Connections (as expected). When I try to right-click on my wireless adapter and choose properties from the context menu I do not get the expected window. I get nothing. The same happens regardless of using the touchpad or the wireless mouse.
Any ideas?
I know I re-install will fix this but I thought this might be helpful to other readers trying to troubleshoot.
Evan
 Post Posted: Sat Dec 22, 2012 3:58 am
What was the last thing done to or on the system before the problem occurred? Scott.
 Post Posted: Sun Dec 23, 2012 10:39 pm
On a complex and fully loaded system recently, the Dropbox context menu would not come up, seems to be a fault even have a short FAQ on the issue https://www.dropbox.com/help/72/en
Point is it would be good to have way to repair the context menu, or even just to learn a little more about it
 Post Posted: Sun Dec 23, 2012 11:15 pm
Other than my children getting a hold of it...nothing that I did out of the ordinary. I haven't installed anything or made any hardware changes. Lately I've put the computer to sleep. The last reboot asked for a Chkdsk (dirty bit flag I assume) and found all sorts of things to fix. I watched it but haven't reviewed the log.
David McMahon wrote:
...even have a short FAQ on the issue https://www.dropbox.com/help/72/en
Are you sure that link is correct? I didn't see anything about hte Cotext Menu.
Also, printing and MS updates seem to be lost and I've reset the services to their default for this system.
Evan
 Post Posted: Sun Dec 23, 2012 11:28 pm
Evan
Was specific to Dropbox, but considered a tool or method to reset the entire context menu, I can imagine it gets corrupted by the likes of Winzip, Dropbox and others
 Post Posted: Sun Dec 23, 2012 11:48 pm
When I followed that link it basically just said to uninstall and reinstall. That is why I was asking.
Evan
