 Post subject: A folder with two names
 Post Posted: Tue Sep 10, 2013 11:00 pm
A few of my hard drives all have a folder with two names. An icon has the name HP_PC. After I double-click on it, however, its name in the address line is HP_CD. IIRC, this situation resulted from a Robocopy job involving Windows Vista that I didn't do quite right. How do I make the name in the initial icon apply to the address line all across the board? Keep in mind that I have observing this situation in Windows XP.
 Post subject: Re: A folder with two names
 Post Posted: Wed Sep 11, 2013 9:20 am
It sounds like there may be some damage or anomalies in the file system. I would recommend opening a command prompt, then type the "CHKDSK /F" command and hit enter. This should repair the file system. If that doesn't help then try directly renaming the folders in question. Scott.
 Post Posted: Wed Sep 11, 2013 9:26 pm
The "CHKDSK /F" command didn't solve the problem. I just changed the name in the initial icon so it will be consistent with the rest of the system. BTW, when I started this thread, it was only one hard drive that had the "HP_PC" thing. I regret my initial error.
 Post Posted: Tue Oct 21, 2014 6:52 pm
It's my understanding that "HP_CD" should have been the correct folder name all along.
