 Post subject: Ms word &PDF reader not working
 Post Posted: Sun Sep 15, 2013 8:26 am
Hi scott, i am working on an Hp625 laptop (250GB,2GB,2GHZ,windows7-32bit).After fresh installation of windws,both ms word(2007) & pdf files would not just open-no any error message,nothing.i also noticed this strange problem with other PCs i try to install.in some case they work for like 2 days & the same problem begings.pls help me out of this dungeon!thanks in advance.
 Post subject: Re: Ms word &PDF reader not working
 Post Posted: Sun Sep 15, 2013 8:37 am
Windows does not include software that supports those file types by default. You will be able to open those types of files after you install software that supports them. You can install Adobe Reader for free, but Microsoft Office is an expensive application. For reading and writing Office files I normally recommend installing the free LibreOffice suite instead. Scott.
 Post Posted: Sun Sep 15, 2013 10:07 am
I have the two programs installed.i even tried foxit reader in place of adobe reader but thesame problem persisted.i experience thesame problem with other pc i tried to installed.
 Post Posted: Sun Sep 15, 2013 10:19 am
If this is happening on multiple systems then it sounds like a problem with malware or possibly your Windows install disc or the software installation source/media has somehow been corrupted. I would do a clean install to a known-good spare drive using known-good installation media as a test. Scott.
 Post Posted: Sun Sep 15, 2013 10:59 am
I suspect the usb hdd from which i am installing it from.i will try your suggestions &give you my feedback.thanks.
 Post Posted: Wed Sep 18, 2013 7:39 am
hi scott,10x alot.I think corrupt HDD containing my apps is the culprit.I tried another HDD with fresh apps & no more aches.
 Post Posted: Wed Sep 18, 2013 2:26 pm
I'm glad you found the problem, thanks for letting us know! Scott.
Users browsing this forum: No registered users and 9 guests
