 Post subject: Is Java software REALLY needed in this day and age?
 Post Posted: Fri Feb 21, 2014 12:39 pm
I ask because Java Quick Starter has apparently interfered with XP Power Schemes of mine.
 Post subject: Re: Is Java software REALLY needed in this day and age?
 Post Posted: Fri Feb 21, 2014 2:35 pm
Java is only needed if you use software that requires it. Some programs that use Java include the Adobe Creative Suite and LibreOffice, you can see more listed here. I do recommend disabling Java in web browsers these days, however you may encounter a site here or there that may require it. If you don't use any software or websites that require Java then I would recommend uninstalling or disabling it. Scott.
 Post Posted: Wed Mar 02, 2016 2:09 pm
Scott, would it be a good idea to prevent Google Chrome from allowing any site to run JavaScript?
 Post Posted: Wed Mar 02, 2016 3:42 pm
You may be confusing Java with JavaScript. The latter is used by most websites today. Scott.
