 Post subject: windows 7 pro being install over windows vista
 Post Posted: Sat May 09, 2015 10:37 pm
I was wondering if windows 7 pro can be install over windows vista basic or windows vista home.
 Post subject: Re: windows 7 pro being install over windows vista
 Post Posted: Sat May 09, 2015 11:22 pm
Yes it can, however in most cases for the best overall performance I recommend installing a new OS from scratch. Scott.
 Post Posted: Thu Jun 11, 2015 4:14 pm
sorry I meant to say if a computer that has windows viata basic install or home can it be that you could install windows 7 pro on them over them or a fully reinstall. With the hardware that came with the computer.
 Post Posted: Thu Jun 11, 2015 8:51 pm
Hardware that supports Vista 64-bit should also support Win7 64-bit. However if one was using 32-bit Vista, then unless they also went to 32-bit Win7 all new drivers would be required for a 64-bit OS install. Older devices may not have 64-bit drivers available. Scott.
Users browsing this forum: Baidu [Spider] and 2 guests
