 Post subject: Windows 10 broke wifi, even when going back to Windows 8
 Post Posted: Tue Oct 27, 2015 8:31 pm
Got a Lenovo Yoga 2 13 here (20344)
http://support.lenovo.com/gb/en/product ... novo/20344
It was running Windows 8, wanted to install 10 so did the automatic updater.
It failed the Wifi after install similar to this KB article.
https://support.microsoft.com/en-us/kb/3084164
After reverting to Windows 8 *and* resetting Windows 8 the issue is still with Windows 8.
I saw this pirential fix, but I don't have the CLSID entry on this Laptop
http://www.askvg.com/fix-network-connec ... ters-list/
***Issue resolved with a minimal msconfig and startup tab boot, offending item removed from boot***
Last edited by David McMahon on Thu Oct 29, 2015 12:14 pm, edited 1 time in total.
 Post subject: Re: Windows 10 broke wifi, even when going back to Windows 8
 Post Posted: Wed Oct 28, 2015 1:36 am
The license sticker should be inside the battery bay. I *never* recommend upgrading (or downgrading) an OS. In this case I would recommend a product restoration (aka OneKey Recovery or factory reset) which should reinstall the original OS, drivers and applications included on the system when it was new. Scott.
PS: If it were mine I would install Windows 7 instead...
 Post Posted: Wed Oct 28, 2015 6:18 am
Thanks Scott, I did try OneKey Recovery sadly the error persists.
This machine like others Win8/8.1 machines has no Licence sticker.
***Just noticed that Windows Safe mode with networking enables the Wifi and I've connected to the network***
***Laptop is working now, one piece of software had caused the problems, safe mode and a Mscofig-edited boot had solved the issue.***
 Post Posted: Fri Oct 30, 2015 1:47 pm
David McMahon wrote:
....***Issue resolved with a minimal msconfig and startup tab boot, offending item removed from boot***
Don't you think you owe us a description of the item removed?
 Post Posted: Fri Oct 30, 2015 7:22 pm
I'm not entirely sure, the issue is semi-random!
On the last "Clean" one-touch factory restore, I found that Wifi was working without having to use safe mode or Msconfig reduced boot.
Also on the last Factory reinstall, I found that Folder options were how I set them last and not MS or Lenovo defaults!
http://windows.microsoft.com/en-gb/wind ... er-options
Above is info for Windows 7, but similar is in Windows 8.
