 Post subject: safe mode reboot
 Post Posted: Wed Oct 28, 2015 5:21 am
Hello
In windows 7 in normal mode I turned on safe mode with networking in msconfig and restarted the machine, but it just keeps rebooting round and round. I tried LKG and safe mode with command prompt but it keeps restarting. I can get to the command prompt from the advanced startup options. I tried to do a sfc /scannow but I get an error saying there is a system repair pending. I ran the command bcedit /enum /v and I can see that Safe boot = network.
I don't have a windows 7 64bit disk to reinstall windows. Is there a way I can turn of the safe mode with networking from the cmd prompt.
Thanks
Ford
 Post subject: Re: safe mode reboot
 Post Posted: Wed Oct 28, 2015 9:33 am
I recommend using Autoruns to check for (and prevent) whatever is running at startup that is causing this problem. Other than that you may need access to a Win7 install disc so you can either use the System Recovery Options or reinstall from scratch. Let me know what you find, Scott.
 Post Posted: Wed Oct 28, 2015 1:08 pm
Hello
Thanks for the links
I put in the product key but error is - the product key you entered appears to be for software preinstalled by the device manufacturer.....
Its a Dell Server, would I need to contact Dell?
I wonder if they would give me a disk.
Ford.
 Post Posted: Wed Oct 28, 2015 8:12 pm
I believe they will: http://www.dell.com/support/article/us/en/19/SLN135486
Scott.
 Post Posted: Thu Nov 26, 2015 6:01 am
Hello
I fixed it.
Tried to run the system restore back about three times and that finally released the pending and the system was able to be rolled back to prior.
 Post Posted: Thu Nov 26, 2015 11:51 am
Excellent, thanks for letting us know the outcome. Scott.
