Author |
spiderman
Post subject: Ghostery for firefox Posted: Sat Jan 16, 2016 10:22 pm |
Post subject: Re: Ghostery for firefox Posted: Sun Jan 17, 2016 12:13 am |
Site Admin |
I don't use it myself, and for most people I don't see the need. On the other hand I would *not* use a browser without installed! If besides ads you want to also disable tracking, Adblock Plus . Scott.
PS: As for the forum issues we had a couple of glitches that should be solved.
spiderman
Post subject: Re: Ghostery for firefox Posted: Thu Jan 21, 2016 9:07 pm |
Post subject: Re: Ghostery for firefox Posted: Thu Jan 21, 2016 9:44 pm |
Site Admin |
Yes indeed. You don't know what you are missing if you haven't tried it. Scott.
spiderman
Post subject: Re: Ghostery for firefox Posted: Fri Feb 12, 2016 3:11 pm |
Attachments: |
Post subject: Re: Ghostery for firefox Posted: Fri Feb 12, 2016 3:30 pm |
Site Admin |
I have the latest versions of both Firefox and Adblock Plus installed and running as I type this, works perfectly for me. I haven't seen problems with any of the sites I visit, and if it there is it can be quickly disabled either just for that site (which it will remember) or completely. Scott.
Maxirad
Post subject: Re: Ghostery for firefox Posted: Sat Feb 18, 2017 6:30 pm |
Check out on ad blockers. Could they do more harm than good?
Post subject: Re: Ghostery for firefox Posted: Sat Feb 18, 2017 11:33 pm |
Site Admin |
They have been in use for years and so far IMHO have done far more good than bad. I would never intentionally want to go without one.
Maxirad
Post subject: Re: Ghostery for firefox Posted: Mon Sep 18, 2017 2:22 pm |
Scott, I have Adblock Plus 2.9.1 for Firefox, but it doesn't seem to block anything at the present time. I know this is a period of transition for Firefox (a page concerning Adblock Plus 2.9.1 does have the word "LEGACY" next to the title), but how can my issue be rectified? Should I replace Adblock Plus with ? (You might to check out.)
Post subject: Re: Ghostery for firefox Posted: Tue Sep 19, 2017 10:08 pm |
Site Admin |
Try uninstalling and then reinstalling, that normally solves this problem. Scott.
Maxirad
Post subject: Re: Ghostery for firefox Posted: Wed Sep 20, 2017 9:55 am |
Scott, your advice apparently worked in my case. Thank you so much!
Maxirad
Post subject: Re: Ghostery for firefox Posted: Tue Oct 10, 2017 6:36 pm |
Maxirad
Post subject: Re: Ghostery for firefox Posted: Thu Jan 04, 2018 7:45 pm |
Scott, the Adblock Plus that I have for Google Chrome may be interfering with Yahoo! Mail. Should I whitelist Yahoo! Mail? Keep in mind that I have two Yahoo! Mail accounts.
Post subject: Re: Ghostery for firefox Posted: Thu Jan 04, 2018 8:15 pm |
Site Admin |
I would test it and base your decision on the results. Scott.
Maxirad
Post subject: Re: Ghostery for firefox Posted: Fri Jan 19, 2018 12:03 am |
Post subject: Re: Ghostery for firefox Posted: Fri Jan 19, 2018 9:00 pm |
Site Admin |
I try to minimize my use of Microsoft products wherever possible. I would use Thunderbird over Outlook. Scott.
Maxirad
Post subject: Re: Ghostery for firefox Posted: Sat Jan 20, 2018 2:02 pm |
Clarification: I currently don't have Outlook installed on the desktop PC I usually use. I use the Outlook website to check e-mail for a certain account of mine when using said desktop PC. Still...
Maxirad
Post subject: Re: Ghostery for firefox Posted: Wed Jan 31, 2018 6:20 pm |
Scott, what do you think of Google's "" thing?
Post subject: Re: Ghostery for firefox Posted: Wed Jan 31, 2018 7:34 pm |
Site Admin |
It looks like . I don't want to block some ads, I want to block as many as possible. I'd just recommend using something like Adblock Plus instead. Scott.
Maxirad
Post subject: Re: Ghostery for firefox Posted: Mon Feb 26, 2018 1:35 pm |
Scott, what do you have to say about Google Chrome's ? It's supposed to be comprehensive.
Post subject: Re: Ghostery for firefox Posted: Mon Feb 26, 2018 9:37 pm |
Site Admin |
So far not much. How does it compare against Adblock Plus? Scott.
Maxirad
Post subject: Re: Ghostery for firefox Posted: Tue Feb 27, 2018 11:32 pm |
Maxirad
Post subject: Re: Ghostery for firefox Posted: Wed Feb 28, 2018 12:16 pm |
Check and out, Scott. Note the concerns about tracking.
