Author |
Post subject: Why Windows 10 Sucks... Posted: Thu Apr 07, 2016 1:40 pm |
Site Admin |
I thought this article was very well written, detailed and especially accurate:  This graphic pretty much sums up the de-evolution of Windows since XP:
brijem
Post subject: Re: Why Windows 10 Sucks... Posted: Sun May 01, 2016 10:39 am |
And it gets better: As if "Cortana" itself were not cringeworthy enough (and any "personal assistant" program, in my opinion) . . . now it's limited to Bing and, ugh, Edge . . . Going to be seeing more and more and more of this. I've been a tech, running my own business for 20 years. I used to love what I did - I enjoyed working with Windows. I'm honestly sickened by what's happening, with Windows and the world of computer software in general - to say nothing of droves of hardware devices designed as disposable.
FascistNation
Post subject: Re: Why Windows 10 Sucks... Posted: Sun May 01, 2016 11:27 am |
Joined: Sun Jul 20, 2008 10:50 am Posts: 508 Location: Phoenix, AZ, USA
waltlip
Post subject: Re: Why Windows 10 Sucks... Posted: Tue May 17, 2016 1:21 pm |
Joined: Mon Feb 23, 2009 7:41 pm Posts: 86 Location: Cinnaminson, NJ 08077
What about all the users with Windows 7 that are facing the decision to go to Windows 10, free download? Except for Linux, it seems to be the only way to go. Is there an option?
Post subject: Re: Why Windows 10 Sucks... Posted: Tue May 17, 2016 3:25 pm |
Site Admin |
Windows 7 support so there are still about 4 years to go. When that time comes I would either continue to use Windows 7 (keeping things like browsers, Java, Flash, etc. updated), move to Windows 10 with added, or look for another alternative such as Linux. Scott.
FascistNation
Post subject: Re: Why Windows 10 Sucks... Posted: Tue May 17, 2016 4:34 pm |
If you are interested in upgrading to Win10 for free, you can make an verified image of your present Win7 or Win8.1 installation, then do the upgrade to Win10. I like Macrium Reflect (free) but AOMEI Backup works well too. Make sure you have the backup disk made so you can boot up the disk and then restore the backup.
Play with it, tweak it, optimize it, whatever. Then make an verified image of it. I would consider not installing much 3rd party apps at this point but make your image. If you want to play around for a couple of months on Win10 after that do so before deciding whether to revert or just drop Win7. But this way you have a fairly virgin copy of Win10 that you can migrate apps and data over to once reinstalled and updated a year from now or two.
Then reinstall your Win7 if desired. The product key still works! Apparently once Win10 is approved, it is always approved so you can switch to Win10 later for free down the line by copying the image to the drive over your Win7 installation IF you did the upgrade before the July 29th deadline.
One caveat: Win10 (and Win8.1) use Secure Boot. Win7 does not. The Win10 installation may activate Secure Boot if it is available on your drive. Once installed Win10 can be a problem to uninstall and put Win7 on the drive unless you go into BIOS and disable Secure Boot just before the reversion.
If you are happy with 8.1 I see little reason not to upgrade to Win10. If you are happy with Win7, I can see why you are reluctant or refusing to upgrade to Win10. Wish there was an easy argument. I am traversing to Linux; Win10 being unacceptable to me from a control, privacy and security standpoint (THX god for GWX Control Panel), and Win7 having less than 4 years to go. So far Win10 looks like a big success, but there are still a lot of Win7 users standing pat. I would not however, wait until the last week or so along with the other fence sitters to evaluate Win10 if you wish. That last week will be a busy one for MS' servers I suspect and why be rushed in your evaluation?
waltlip
Post subject: Re: Why Windows 10 Sucks... Posted: Tue May 17, 2016 5:28 pm |
My thanks to both of you for your prompt and very informative replies. I have suitable spare hard drives, so I may try cloning Windows 7 Pro with Apricorn, before trying imaging.
FatGuy
Post subject: Re: Why Windows 10 Sucks... Posted: Wed Jan 18, 2017 12:41 pm |
FatGuy
Post subject: Re: Why Windows 10 Sucks... Posted: Wed Jan 18, 2017 1:19 pm |
I know nothing at all about Linux, not sure I'd be able to get drivers for all my hardware working on a new pc. Guess I'll stick with Windows 7. Even when they stop updating it, it should be fine correct?. I mean I still see a lot of businesses running XP.
Post subject: Re: Why Windows 10 Sucks... Posted: Wed Jan 18, 2017 5:02 pm |
Site Admin |
The article you posted above incorrectly characterizes Microsoft's intent to move people to Windows 10 before Windows 7 support ends as an indication that Windows 7 is somehow "dangerously insecure", which is rediculous. You will be fine sticking with Windows 7 until the end of support, and even for some time thereafter. Scott.
FatGuy
Post subject: Re: Why Windows 10 Sucks... Posted: Wed Jan 18, 2017 6:01 pm |
Yes Scott I thought that that was kind of crazy. It's too bad things have to go this way.
FatGuy
Post subject: Re: Why Windows 10 Sucks... Posted: Sun Mar 05, 2017 2:57 pm |
Scott I have the link you posted in the first post saved, but it doesn't seem to ever stop loading. Maybe it's my adblock extension or something.
Post subject: Re: Why Windows 10 Sucks... Posted: Sun Mar 05, 2017 4:47 pm |
Site Admin |
It works for me and I also have adblock running. Note that the link is from Archive.org as the original page is down, and archived pages usually take longer to load than the original. Scott.
Maxirad
Post subject: Re: Why Windows 10 Sucks... Posted: Fri Nov 10, 2017 4:06 pm |
Scott, you still don't recommend Windows 10, right?
Post subject: Re: Why Windows 10 Sucks... Posted: Fri Nov 10, 2017 11:26 pm |
Site Admin |
Windows 10 will be the only choice after Windows 7 is no longer supported. Until then I recommend Windows 7. Scott.
Maxirad
Post subject: Re: Why Windows 10 Sucks... Posted: Sat Nov 11, 2017 12:05 am |
Scott, will Windows 7 essentially be SOL after the end-of-support date even with a supported browser?
Post subject: Re: Why Windows 10 Sucks... Posted: Sat Nov 11, 2017 1:05 am |
Site Admin |
I would say that using a fully supported browser would allow the OS to be used safely well after the date the OS is no longer officially supported. Scott.
Maxirad
Post subject: Re: Why Windows 10 Sucks... Posted: Thu Dec 07, 2017 10:03 pm |
FatGuy
Post subject: Re: Why Windows 10 Sucks... Posted: Fri Dec 08, 2017 1:27 pm |
I've seen a few doctors offices, hospitals and some gyms use Windows XP.
Maxirad
Post subject: Re: Why Windows 10 Sucks... Posted: Tue Apr 03, 2018 5:16 pm |
Um, is Windows 10 supposed to be the Windows operating system to end all Windows operating systems?
Maxirad
Post subject: Re: Why Windows 10 Sucks... Posted: Sun Apr 08, 2018 8:04 pm |
Scott, why do you think Windows 10 necessary for playing DVDs?
Post subject: Re: Why Windows 10 Sucks... Posted: Mon Apr 09, 2018 10:06 pm |
Site Admin |
Because Microsoft doesn't want to that would be required for Windows to play DVDs. But that is no problem as I would recommend downloading the VLC media player which has that decoder (and ability) built-in: https://www.videolan.org
Maxirad
Post subject: Re: Why Windows 10 Sucks... Posted: Wed May 02, 2018 11:23 pm |
Consumer advocate Clark Howard the free Windows 10 upgrade back in 2016. *sigh*
