 Post subject: why is windows update slow and I can't get windows to updat
 Post Posted: Tue Nov 15, 2016 4:52 pm
What is going or causing windows updates not to update. I unable to update last months updates and this months updates what is going on. do I have a update that needs to be remove before the updates works again. the windows update is slow and stuck. on windows updates.
This is getting very sicking If Stupid Microsoft wants me or anyone to upgrade to windows 10 they better fix windows updates this is bull.
I don't have that one update that cause the windows updates to be slow. But is there another one that I don't know.
 Post subject: Re: why is windows update slow and I can't get windows to up
 Post Posted: Tue Nov 15, 2016 10:53 pm
Windows Update has many problems, this may help: https://support.microsoft.com/en-us/kb/3102810
Or it may not, as this has been an issue for quite some time now. I find it amazing that MS continues to make what should be a simple and fast process so difficult and slow. Scott.
 Post Posted: Thu May 25, 2017 6:57 am
Update for Windows 7 for x64-based Systems (KB3102810)
Is the x64 is that for windows 7 pro 64bit
and is the x86 is that for windows 7 32 bit.
I just want to know which one to download form that link you posted
I am piss off at Microsoft super piss off.
 Post Posted: Thu May 25, 2017 10:16 am
That is correct. Scott.
 Post Posted: Fri May 26, 2017 7:53 am
All supported x86-based versions of Windows 7 Download Download the package now.
All supported x64-based versions of Windows 7 Download Download the package now.
All supported x86-based versions of Windows Embedded Standard 7 Download Download the package now.
All supported x64-based versions of Windows Embedded Standard 7 Download Download the package now.
All supported x64-based versions of Windows Server 2008 R2 Download Download the package now.
All supported IA-based versions of Windows Server 2008 R2 Download Download the package now.
I have windows 7 64bit what do I need to download and install here to speed up windows update do I need to download all the x64 packages or just the or just tell me which one to download cause I don't understand which one will be ok to download and which one not to.
there is a new malware vrius out to and need to patch this up right away.... It been a long time since I update windows the last time was back in 8/2016 is when the windows updates start to act up... and slow and take hours and hours for it to get the updates.
what are you thoughts about windows 10 now scott.
 Post Posted: Fri May 26, 2017 2:45 pm
The 2nd one from the top in the above list is correct for Windows 7 x64.
For most people I continue to recommend staying with Windows 7. Scott.
 Post Posted: Thu Jun 01, 2017 1:44 am
I all ready had that update install. But it still took along time for it to updated. I let it run for about 6 hours last night took forever.
So I don't what the cause of it or what updated is causing it to be so darn slow.
Have you run into this scott.....
but anyways I got the updates and block wannacry malware lol...
