Scott Mueller's Upgrading and Repairing PCs Forum • View topic - Microsoft Teredo Tunneling Adapter Problem
 Post subject: Microsoft Teredo Tunneling Adapter Problem
 Post Posted: Sun Dec 11, 2016 11:18 am
On my Windows 7 Pro 64 bit pc in the "devices and printers" section my computer which I named "Steve-Pc" has an error icon next to it. The familiar yellow triangle with an exclamation point in the middle. So I right clicked, and clicked properties and under "device status" of "Microsoft Teredo Tunneling Adapter" it says "This Device cannot start. (Code 10)". I have no problems with my pc and the only reason I was in the Devices and Printers section was because I needed to check on my printer because my other pc couldn't connect and I've already fixed and handled that situation.
 Post subject: Re: Microsoft Teredo Tunneling Adapter Problem
 Post Posted: Sun Dec 11, 2016 11:22 am
I found this on a different forum,
"Here's what worked for me. It's in the windows knowledge base.
In the start menu search bar type in REGEDIT to open the registry editor. Navigate through the following: HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\SERVICES\TCPIP6\PARAMETERS. In the right pane, right click Disabled Componets and select edit. Set the DWord value to 0. Restart your computer and the teredo tunneling adapter will now start.
Good luck to all. Try this. Its easy and it works."
Scott, I'd like to hear more about this from you. Is the action in the above quote a good idea?
 Post Posted: Sun Dec 11, 2016 1:28 pm
It sounds fine to me. You can always make a note of the existing DWord value and set it back if necessary if changing it causes any problems. Let me know if changing the value solves the problem for you. Scott.
 Post Posted: Sun Dec 11, 2016 1:41 pm
Existing Dword value for Hexadecimal is 8e. Thanks!. I'll try changing it to 0 now.
 Post Posted: Sun Dec 11, 2016 1:53 pm
Ok so the registry edit worked and now there are no errors listed. So now no Microsoft Teredo Tunneling Adapter is listed. Is this "Tunneling Adapter" even needed?.
 Post Posted: Sun Dec 11, 2016 1:57 pm
Ok now I went back into Regedit and looked and the value is still set to 8e. What is going on here?.
 Post Posted: Sun Dec 11, 2016 2:17 pm
Ok so I read and figured out that normally the Teredo Tunneling Adapter is hidden and it only showed up because there was an error with it. When I went into device manage and looked for it, it showed up after enabling "show hidden devices".
 Post Posted: Sun Dec 11, 2016 2:20 pm
I'm just confusing myself over here.
 Post Posted: Tue Nov 07, 2017 5:01 pm
I just found this same error on my wifes Window 7 computer. I just uninstalled it. Now it's gone. I'm not sure if it's needed or not but I don't think so. Scott, could you give me more information on this?. Should I have uninstalled it?.
 Post Posted: Tue Nov 07, 2017 8:25 pm
Here is a recommended repair procedure: http://www.dell.com/support/article/us/ ... 0-?lang=en
Here is some more information: https://en.wikipedia.org/wiki/Teredo_tunneling
 Post Posted: Wed Nov 08, 2017 3:00 pm
Thank you Scott. That is how I fixed it last time. This time though I had to reinstall the Microsoft Teredo Tunneling Adapter. Based on the information that I've read I'm not sure that it's even used by the operating system. Most of the internet is still using Ipv4 correct?. So in that case the operating system would have no use for this "adapter". Correct or no?
 Post Posted: Wed Nov 08, 2017 11:32 pm
That is correct, which is why when it cannot start nothing is really affected. Scott.
