Author |
brakers
Post subject: Upgrading from Windows XP to Windows 7 Posted: Tue Dec 26, 2017 1:47 pm |
Hi Scott
I have been using Windows XP for a long time and I need to update. I was told that Windows 10 would be the way to go but after reading of some peoples experiences and some of what you have written about it on your forum, I am unsure of what I should do.
I have a licensed copy of Windows 7 Pro (32 bit) which I bought a while back but never used due to being so used to XP.
I would be grateful for any advice .
Thank you
Paul
PS : I have just got the latest Upgrading And Repairing PC's . I was really pleased that they have made the hard cover version available again.
Post subject: Re: Upgrading from Windows XP to Windows 7 Posted: Tue Dec 26, 2017 4:21 pm |
Site Admin |
Paul,
Thanks for buying the latest book! Windows 7 will be supported until 2020 so for now I still recommend using Windows 7, especially if you already paid for it. Scott.
brakers
Post subject: Re: Upgrading from Windows XP to Windows 7 Posted: Tue Dec 26, 2017 5:57 pm |
Hi Scott
Many thanks for the fast reply. Just one more question if I may . Does Windows 7 give me the option to migrate all my XP files ?
Paul
Post subject: Re: Upgrading from Windows XP to Windows 7 Posted: Tue Dec 26, 2017 9:41 pm |
Site Admin |
brakers
Post subject: Re: Upgrading from Windows XP to Windows 7 Posted: Tue Dec 26, 2017 11:29 pm |
Hi Scott
Many thanks. I will follow your advice
Paul
spiderman
Post subject: Re: Upgrading from Windows XP to Windows 7 Posted: Sat Dec 30, 2017 5:27 pm |
Post subject: Re: Upgrading from Windows XP to Windows 7 Posted: Sun Dec 31, 2017 12:30 am |
Site Admin |
