Author |
brakers
Post subject: Moving From Windows 7 Pro t Windows 10 Posted: Sat Jan 18, 2020 4:26 pm |
I have just got the reminder screen from Microsoft that support for Windows 7 has ended. I am thinking of going to Windows 10 either Home or Pro. I want to ask you if I should go for a download via Microsoft using my existing desk top PC or should I get a new set up. I have attached the specs of my current PC. I would be grateful for a reply.
Paul
Maxirad
Post subject: Re: Moving From Windows 7 Pro t Windows 10 Posted: Mon Jan 20, 2020 1:06 pm |
Scott prefers clean installations of operating systems.
brakers
Post subject: Re: Moving From Windows 7 Pro t Windows 10 Posted: Mon Jan 20, 2020 3:31 pm |
Post subject: Re: Moving From Windows 7 Pro t Windows 10 Posted: Sat Feb 22, 2020 11:24 am |
Site Admin |
Most systems running Win 7 should also be able to run 10. If upgrading I would recommend a clean install from scratch. Scott.
brakers
Post subject: Re: Moving From Windows 7 Pro t Windows 10 Posted: Sat Feb 22, 2020 12:06 pm |
Many thanks for the advice .
Regards
Paul
