Scott Mueller's Upgrading and Repairing PCs Forum • View topic - Cheetah 10K SCSI hard drive issue
 Post subject: Cheetah 10K SCSI hard drive issue
 Post Posted: Fri Feb 28, 2014 5:34 pm
I have 2 SCSI U320 hard drives for my server that I am having an issue with.
Both drives, when installed into the server power up, and spin up fine, but, they are not recognized when it comes to trying to configure them.
I would have thought from the documentation that the default configuration would work, but, it does not.
I know the J6 would be the configuration jumper, but, am not up enough on servers to know which SCSI ID to use based upon which position I have it in the chain.
I would also assume that I would need to remove the resistor(s)? The current drives I have in the server do not have configuration jumpers. These are the only 2 in the batch of 10 that came in my lot have have them.
Do these need jumpers for properation?
 Post subject: Re: Cheetah 10K SCSI hard drive issue
 Post Posted: Fri Feb 28, 2014 6:46 pm
 Post Posted: Fri Feb 28, 2014 8:47 pm
This is exactly what I thought.
I have 2 of these drives that remain unrecognized.
The rest of the drives I have (not the same brand) work fine.
I've done no configuration so to speak of the backplane, I've just slid the drives into the slots, powered on the server, and attempted to configure RAID.
It is at this point where the controller is not seeing these drives.
The "green" power light is lit, but, the "green" access light never does light.
 Post Posted: Fri Feb 28, 2014 9:34 pm
It sounds like those drives may be defective. Scott.
