Scott Mueller's Upgrading and Repairing PCs Forum • View topic - Esxi Server
 Post subject: Esxi Server
 Post Posted: Mon Aug 03, 2015 2:27 pm
I'm looking to build a server for virtualisation with Esxi. I initially looked at buying something like a Proliant Dl380 but was warned about the running costs. Instead I thought about just using desktop hardware and building my own. With that in mind, what would thoughts be on something such at with (eventually) 64GB of RAM and maybe a Core i7 4930k?
 Post subject: Re: Esxi Server
 Post Posted: Mon Aug 03, 2015 6:25 pm
I assume you have this laying around or can get it used cheap? 2012 x79 board. And when it comes to ASUS and Scott .... :-)
It certainly can do virtualization assuming esxi supports the MB and CPU.
https://www.vmware.com/resources/compat ... search.php
 Post Posted: Mon Aug 03, 2015 8:00 pm
 Post Posted: Wed Aug 05, 2015 2:04 pm
 Post Posted: Wed Aug 05, 2015 8:05 pm
You could get a higher clock rate 4-core processor with a less expensive motherboard for overall less than a 6-core setup, which for many applications might even perform better. But a lot depends on what you are using the server for and how many users will be connected. For example an SQL server running a large database application with many users could probably use more cores, but for simple file and print sharing I believe that may be overkill. Scott.
 Post Posted: Thu Aug 06, 2015 4:02 pm
