 Post subject: RJ-45 connector repair
 Post Posted: Tue Jul 13, 2010 5:37 pm
I have a RJ-45 Ethernet port that was damaged by having a USB Type B connector plugged into it. Unfortunately it is on a color laser printer and it is physically attached to the main $850 printer control board.
I cannot find RJ-45 connector repair instructions in either URPC19 or URNet5, or on this forum. So should I break out the soldering iron, or do they make RJ-45's so you can pop out a damaged connector and plug in another one?
I haven't opened up the printer yet to look at the board to see how it is connected.
 Post subject: Re: RJ-45 connector repair
 Post Posted: Tue Jul 13, 2010 5:45 pm
Sounds like you need one of these, which would definitely require a fairly simple soldering job to remove and replace. Scott.
